Finally made it to the 1/4 mile
Old Feb 18, 2006 | 08:55 AM
Warrtalon's Avatar
Originally Posted by EVO-8-Nate
I felt the same way!!! I finished 1 1/2 -2 car links ahead and trapped a lower time and MPH???? WTF!!!
That means your R/T was a lot better.
Old Feb 18, 2006 | 08:58 AM
EVO-8-Nate's Avatar
Yes, you only gained 20mph which suxxxxxxxxxxxxxx. That usually only happens on stock cammed cars that peak early. Even my stock-cammed 05 picks up no less than 22mph on the back-half. Yes, I have the 10.5, but I've seen plenty of 9.8s on here with big top-end due to their cams and cam gear settings.
If you had your same launch from before with the 7.85 1/8th-mile, though, you'd probably have run a high 12.1 or so.
I agree! I am embarrassed with my 60fts. My car just kept slipping on the launch the track prep there was horrible and I needed to re-learn my clutch all things that add up to me running ****ty times.
As far as the back half my check engine light came on right before we pulled into the strip 05whiteEVO8 saw it himself. I think that I'll go to auto zone and see what fault pops up. It might have been pulling timeing which would explain a little??? It is usually a random misfire code!
-Nate
Old Feb 18, 2006 | 09:02 AM
boosten's Avatar
60's
Cut some better 60 fts and you will be on your way to some very low 12's good luck.
Old Feb 18, 2006 | 09:07 AM
05WhiteEVO8's Avatar
his was .4 and mine was .7
Old Feb 18, 2006 | 09:08 AM
here is the slip
Attached Thumbnails Finally made it to the 1/4 mile-montgomery-slip.jpg
Old Feb 18, 2006 | 10:11 AM
TrinaBabe's Avatar
You always need to remember that launch and 1-2 shift is what makes the pass good or not. Consider one of my times vs. Matt Smith:
Mine 60' 1.719, 1/8th 7.535 @ 94.5, 1/4 11.605 @ 122.08
His 60' 1.702, 1/8th 7.265 @ 99.27, 1/4 11.312 @ 122.87
You can clearly see when he beat me.... his launch was slightly better but the main difference is the 1-2 shift/2-3 shift. Im not sure if I short shifted the hell out of first or the tires spun when I hit second but thats obviously the difference. The cars trapped almost the same, the launches were close. Its the shifting that made a HUGE difference between these runs... think if it made a difference from an 11.6 to a 11.3 from just the first few seconds of the track. The rest of the track doesnt matter... then its whatever the car can do.
Old Feb 18, 2006 | 10:12 AM
TrinaBabe's Avatar
Oh and by the way... in those two runs look at how much more power my car makes...
I gained 27.58 mph, he only gained 23.6 mph. So imagine... a much more powerful car, trapping the same and running a slower ET. That should put it into perspective on how much driving actually matters.
That should let people know its alot more than making a powerful car....
Old Feb 18, 2006 | 10:15 AM
TrinaBabe's Avatar
I think Ill make a new thread showing this so more people can see it...
Old Feb 18, 2006 | 11:38 AM
boosten's Avatar
time slips
Dude judging by your time slip you have plenty of room for improvement cut those 60's to low 1.7 to high 1.6 hit your shifts and hang on
Old Feb 18, 2006 | 11:44 AM
Danny23's Avatar
how did you launch, slipping the clutch or dumping it?
Old Feb 18, 2006 | 12:12 PM
Warrtalon's Avatar
Yah, so he finished .3s sooner, which is 2-3 car lengths. He shouldn't have been surprised like he was.
Old Feb 18, 2006 | 12:18 PM
EVO-8-Nate's Avatar
Yeah, yeah!!! You know how it is...
-Nate
Old Feb 18, 2006 | 01:49 PM
Slipping it.
Old Feb 18, 2006 | 02:26 PM
I did run some gas for safety but did not change any settings. Just FYI. Still on 22-23PSI as well
Ah, so this was on race gas. YOu absolutely MUST mention that when posting 1/4-mile times. I would have expected that mph on pump gas, but on race gas, you can get upwards of 116mph on those mods. The driving is good, but continuing to launch with the limiter is probably messing you up. Maybe you'll get it figured out eventually, but I don't waste my runs, because they aren't finite. Despite the 1.8 60', the ET is still good.
I find it interesting how much difference there is in your 1/8th-mile MPHs and 1/4-mile MPHs. Very weird that you two were so different...
EVO-8-Nate
For Sale - Cars For Sale
Aug 31, 2012 11:14 AM
EVO-8-Nate
Feb 16, 2006 02:04 PM
EVO-8-Nate
Feb 9, 2006 05:37 PM
EVO-8-Nate
95
Jan 12, 2006 10:37 AM
evocrazy
Jul 17, 2003 09:38 PM
