GTKage's EVO IX updated times
wanted to ask, would Evo IX's with the 5 speed eventually have to shift into 5th after a cretain whp since they are already almost bouncing of the rev limiter due to the shorter gear ratios? Would it mean that 03-05 would be capable of trapping higher due to the longer gearing?
03-05 5 speed is better for drag racing
the Evo IX trans is best suited for road racing IMO.
it s is possible to run 11.9 with the 4th gear with the IX's but anything faster u ll have to shift into 5th, and in that case the IX MR is better off because that gear is shorter than the 5speed's 5th gear, therefor giving it better acceleration.
Originally Posted by GTKage
1-4 on the evo IX's 5 speed and 6 speed are indentical
So on the IX's 5 speed it will be a disadvantage bc shifting into 5th will result in a slower 1/4 mile time and a lower trap speed, am i correct?
Yes, IXs will be at the same disadvantage as MRs.
Kage, your personal preference is fine - I wasn't talking about that. I just didn't want people to think what Scott says was true for every tuner. Al spend a ton of time learning how NOT to fry the ECU with Techtom before he started providing the service to customers. If people would rather pay the $650 minimum for the EcuTek license, then that's their prerogative. Maybe you can go as fast with your EcuTek as I did without any flash on my VIII.
Techtom is not unreliable in Al's hands, and he is not frying ECUs.
My source of info is reliable that the techtom equipment for IX's have rendered a many IX ECU's useless. The cost for a replacement ECU is in the realm of $865 from the dealer.
but we ll see.
Originally Posted by TTP Engineering
****, I'll pay Kage $20 to take a pass just to beat warrelton. Then we can start selling GTKage packages for 11.8's and 100 octane.
i might go tonight if scott is going. but i dont know if i ll run.
Jay
I want to point out that this post alone from Warrelton has brought Al into this thread , not us. No where was he mentioned. Thanks for slinging the mud.
It doesn't matter if you mentioned Al or not, because I didn't even say that you were talking about Al. I said that when Al uses Techtom for his IX flashes, it is not unreliable and that he doesn't fry ECUs. That is all.
