Stock Pulling 1.5 foot
Originally Posted by Ev0ikon
1.5!!!? I dint' even think it's possible on stock clutch. just WOW!
ya i think i can get down even lower on stock cluch if i lower tire pressuer and up the 2step. but i would like to run safe.
Originally Posted by mike1023
warrtalon remeber im on stock cluch now with aftermaret i will hit the 1.4 maybe 1.3 on a good day.
Originally Posted by sleet
Being how AMS only cuts 1.5s with an aftermarket clutch, slicks, and 800WHP+, I doubt you'll get any lower than that. I don't think anyone has gotten any lower than 1.5 yet?
also a 800hp car cant be that easy to drive. and if i had slick woot be fun. im going to get some and i will pull 1.3 for ya. ok .
Mike all I have to say is you must be doing some amazing driving off the line, because when I ran against your car it didn't have the pull in high gears to be an 11 second car. Congrats, hope to see you at atco again
acto if i remeber i was not driving that time my car raced you my friend wanted to go at it and see if he can hook the car better. and also my car was little diff setup from then to now. but thanks for the grats
Originally Posted by 3240
Mike,
Great driving, anything close to a 1.6 is impressive in my book.
Can you post the time slips again? The pictures that you posted are too faded to read. Thanks.
hehe thanks and i will scan when i get home i scaned them in from work.
nice runs, I've done several 1.5's on the stock clutch and all season tires. Running an aftermarket clutch is more tricky, I highly doubt you will come close to a 1.4, unless your run slicks, but then your clutch will not hold... somethings got to give.
http://www.titsup.mike1023.com/video...0pump93%20.jpg
http://www.titsup.mike1023.com/video...egas116%20.jpg
there ya go scan it in again
Originally Posted by Az3ar
some drivers are just better than others. If its true then congrates.
Althoug it does not take too much to learn how to launch a car...
yes and no to this. but the main thing going at is that look how many miles i have on cluch along with launch and dyno runs. so geting these times with it is just amzing.
