Stock Pulling 1.5 foot
1.3 or 1.4...right Mike...
Originally Posted by sleet
Being how AMS only cuts 1.5s with an aftermarket clutch, slicks, and 800WHP+, I doubt you'll get any lower than that. I don't think anyone has gotten any lower than 1.5 yet?
Look at fimotorsports for example... He was pulling 1.5 60fts with the stock clutch, stock turbo, and all season tires. He then approximately doubled his horsepower and torque with the GT37R/stroker, added a stronger clutch, drag radials, etc. & is now pulling either the same 1.5 60fts or slightly worse 60fts (low 1.6's).
Bottomline is it's not easy getting all that power down to the ground out of the hole, especially when you want to do it without breaking stuff. This is why so many drag racers opt for a RWD platform... It's usually more efficient, less complex, and easier to pull a good 60ft than an AWD car with all else being equal.
Originally Posted by Az3ar
some drivers are just better than others. If its true then congrates.
Althoug it does not take too much to learn how to launch a car...
Originally Posted by S4 Playin w/u
If an S2000 running Nitto drag radials can pull a 1.42, why is it so hard to imagine an Evo with 4 BFG Drag Radials pulling that? I think with a stronger clutch, higher two step, and a bit more power, Mike can cut a high 1.4 60ft.
Again, congrats on some impressive driving!
Originally Posted by 3240
As much as I'd like to see him cut a 1.4 60' time I think it's going to get even more difficult with an upgraded clutch and more power. I might be wrong though.
Originally Posted by mike1023
my setup is diff now.
-tbe
-mbc
-intake
-hks 264/272
-fuel pump
-tune is way off geting knock and needed to be tune right.
but the most off i was doing was for 60 foot and can see i have rech a crazy launch with this car on a stock clutch. just wait till i get a aftermarket one. say 1.4 maybe 1.3 if can do it.
-tbe
-mbc
-intake
-hks 264/272
-fuel pump
Despite the very low 1/8 mph for a 7.6 ET (you shift supersonic), note the 90mph 93 octane vs 87mph 116 octane.
This tells me you have so much more time to lose with just high oct/boost tuning. I bet at least 0.2 sec in the 1/4.
Man, good shifts
Man, good shifts
