you're about to line up, what do you do?
You don't understand. You don't burnout IN the water box. You roll th rough the water box, which makes the tires a little wet, then you let 'em loose on the tarmac. There is no slip'n'slide. With the water on the tires and a high rpm burnout, I get an idea for how sticky the launch pad is, because I either sit and spin in place, or I spin while actually moving forward at varying speeds. I've been doing this for a long time, so I know how to gauge the relative stickiness. Just because you have no idea how to do it doesn't mean I don't...
I have ACT, EXEDY and Tilton clutches on sale. I also have 2 5sp trannys and 3 transfercases both ACD and non ACD for those who break theirs and do not have the time or $$ for a rebuild. PM me if needed after your burnouts.
Why's that? NO different than any other car doing a burnout. In fact, I do much less spinning and spit back much less debris than a true FWD or RWD burnout. Not sure what your comment was referring to...
Originally Posted by 2muchboost
Is it that much stress? I figured if its wet, the tires spin freely, and its not that much stress...?
sorry for taking so long to reply, but your right when the tires are wet its a lot less stress but street tires dont even respond better enough to make it worth a burn out, they are created to be ready at stock driving temperatures.
plus doing a burn out is harder than not doing one... every time you do one you put your drivetrain at risk, and wear that much more tire.
i just dont think its worth doing one unless you have tires that need to be heated up, and you are trying to break records..
