Finally launched the car...
Old May 5, 2006 | 08:20 PM
Ultimate CC's Avatar
I went to track again, did minimal tuning but decided to launch the car this time. I really need to work on the tune but maybe I will get a chance tomarrow. It was knocking in 4th a good amount and any count above a 2 count pulls 7 degrees of timing for every 1 count. So a 4 count pulls 14 degrees. I do this as an additional failsafe for the methanol. These runs were on 50% meth. The last two passes I was getting crazy wheel spin and couldn't get traction. I will try and go back tomarrow, tune the car some more, lower the tire pressure as it was at 35f 37r. I may go get tuned professionally one of these days as I really want to hit 11s but this knocking here and there is killing me.
1. 1.726 88.76 12.169 114.32
2. 1.764 88.95 12.164 114.98
3. 1.878 89.32 12.229 115.42
4. 1.819 88.86 12.219 115.08
Old May 5, 2006 | 08:22 PM
superscout03's Avatar
very very nice, I like it alot. Wow did I beat warrtalon to a thread?
Old May 7, 2006 | 12:37 PM
I thought I was going to get to track today but got up too late, next friday...
Old May 8, 2006 | 03:26 PM
C6C6CH3vo's Avatar
Good MPH. Especially the gain from the 1/8 mil to 1/4
Put 90% methanol or more in there. water has more potential but you need NASA resourses and PhD's to reap its benifits.
Seriously, have you run stronger methanol yet?
Old May 8, 2006 | 03:59 PM
nope, still working on my 50% meth tune, once thats done I will start on the 100%...
Old May 8, 2006 | 06:33 PM
dryad001's Avatar
Wow we are right next to each other in times and speeds.
EDIT- I get a hold of you over PM.
Old May 8, 2006 | 06:53 PM
BSREVOLUTION's Avatar
did you use the launch controller on the utec? justin
Old May 8, 2006 | 07:18 PM
Yea I had it at 5600 with the UTEC, gonna go back on weds and friday and lower it a bit with less tire pressure so I can hit some 1.6s...
Old May 9, 2006 | 01:11 PM
kevo's Avatar
Yeah I think you can hit 11s without much problem with a better launch!
Old May 9, 2006 | 03:04 PM
Yea and I think with a little faster 1-2 shift I will be in the 11s
Old May 11, 2006 | 11:13 PM
what rpm are you shifting at? and are you using the no-lift shift?
Old May 12, 2006 | 09:31 AM
first and second to 7700 and third at 7600 and no lift shift from first to fourth...I was looking at time slip more and my 330 is 5.0ish when it should be more like 4.9ish and my 1000' is 10.2ish when it should be more like 9.9-10.0...I am not sure why its like that, maybe its my shifting but I feel I am doing a pretty decent job of shifting at this point...
Old May 12, 2006 | 12:09 PM
C6C6CH3vo's Avatar
Were all four runs NLST?
115mph traps should be quicker, must be the shifting
Old May 12, 2006 | 01:32 PM
115 was from excessive spinning off the line though, I was having trouble with traction. All passes were NLST.
