Disappointed in my times:
Old Jun 22, 2006 | 05:25 AM
1BlackEvo9's Avatar
Well guys I took my 06 IX to the track last night and I thought I would be faster than I was. Here is what I ran:
R/T - .731
60' - 2.141
330 - 5.718
1/8 - 8.620
MPH - 83.96
1000 - 11.113
1/4 - 13.179
MPH - 109.46
Here are my mods:
BR TBE (Catless)
Hallman MBC running 24 psi
HKS Intake
AMS LICP
Mail in Tune from Dynoflash
I was hoping for a mid to high 12 sec run with these mods. What do you think is wrong, is it me or is it the car??
Old Jun 22, 2006 | 05:32 AM
lexat20's Avatar
I'm no pro driver but your 60' should be closer to 1.80 or quicker. That alone would put you in a mid to high 12
Old Jun 22, 2006 | 05:41 AM
Smike's Avatar
Yep, 60 footers killed your time. And 24 psi - higher (100+) oct?
How were you launching?
Old Jun 22, 2006 | 05:43 AM
1BlackEvo9's Avatar
I know my 60' sucked but I didn't think that would kill a 1/2 sec from my time. As far as my boost, do you think I should turn it down a little? I was just reving to about 4200 and popping the clutch, then I tried slipping the clutch and well I think I slipped it a little to much because the revs went up but the car didn't move...LOL
Need a new clutch now...
Old Jun 22, 2006 | 05:45 AM
MANGOOK's Avatar
Your trap would equal to a mid 12 second pass just get your launch down and you are good to go. You have a nice trap though especially with your 60ft.
Old Jun 22, 2006 | 05:48 AM
1BlackEvo9's Avatar
Cool, so that means it's just driver error and not the car. I just need to practice my launches a little.
Old Jun 22, 2006 | 05:49 AM
Smike's Avatar
Yes that would kill your time. I wouldnt run 24 psi unless I was on racing fuel. If you are on 93 oct I would only go to 21-22 psi.
You have a IX, like me you have a 5K limiter. At the line - get into the lights, stage, put your foot to the foor - the RPMs will bounce on the 5K, building 8-10 psi of boost. Take the slack out of the clutch, yellow, yellow, green - walk the clutch back quickly, then let go of it at the top of the throw.
I doubt you need a clutch - there is a restrictor valve in the factory line that causes the clutch to slip like that when you just try to drop it.
Old Jun 22, 2006 | 05:54 AM
1BlackEvo9's Avatar
Ok, I will give your suggestions a try and hope I turn some better times.
Old Jun 22, 2006 | 08:42 AM
itzwolf's Avatar
You definitely got mid 12 second trap times. I used to get 12.6 consistently with a 108mph trap, and a 1.8/1.9 60' on an 03 Evo.
Keep practicing and you'll get it
Old Jun 22, 2006 | 10:08 AM
1BlackEvo9's Avatar
Thanks, I will
Old Jun 22, 2006 | 05:09 PM
NIevo's Avatar
Yeah its your 60's for sure. A low-mid 12 is possible with a 108-109trap. First turn your boost down and then work on the launches. Last year I ran a 1.68 on one run and pulled a 12.3@108 and on another run pulled a 2.2 60' and ran a 13.1@109 so you can see how big a difference it makes.
Old Jun 22, 2006 | 05:13 PM
dustin03's Avatar
wow I ran better than that in my 03 with less mods
Old Jun 22, 2006 | 06:01 PM
06evofiji's Avatar
Man that sucks, I have less than you and ran a 12.6 at 109, My 60 was 1.880 though. You need to work on that man. Also launch from about 5500 atleast and where are you shifting at?
24 PSI wow thats alot I run 19 MAX with my hallman and I think thats pushing it. Just work on launch man and clean shifts...good luck
Old Jun 22, 2006 | 06:02 PM
06evofiji's Avatar
Oh and just for a ref. I'm a bad driver and ran a 13.0 sec flat totally stock in a 9GSR
Old Jun 22, 2006 | 07:40 PM
NIevo's Avatar
Why are you only running 19psi? Thats less then stock and no where near pushing it. You can run 21-22psi with no problems on our gas.
