Took my car to the 1/4 track last night
Bah, you guys at like Evos haven't been doing this for the duration of their existence. We run 21-22psi on 93oct, and you can run as much boost as the stock turbo can give you on race gas even without a change in tuning. In fact, when we change the tuning on race gas + boost, we LEAN OUT the AFRs _and_ add timing. So, not changing the tuning is even safer, because the AFRs and timing are not as aggressive.
Dude, stop. Of course I know all this already. I've tuned a few Evos in my day.
And in this instance, obviously everything was not all right. A dedicated low octane map like Mitsubishi and every other reflasher uses would've likely saved the car from too much boost.
Are you also trying to tell EvoM that at altitude you can run the stock turbo wide open as long as there is some race gas in the tank? Don't believe that.
Again, this isn't flaming, its black and white fact and tech talk. Bottom line is that the boost increase killed the engine. Had it stayed in the boost parameters it was tuned for, this never would've happened.
I hate it for the thread starter that he lost his engine, but hopefully by posting this, others will not replicate his mistake.
Sorry, it's a bad idea to ASSUME anything like that is safe. The ECU will pull timing but if it is severely lean and you crank up the boost the ECU will not pull enough timing to keep from doing damage. A good example is the original poster of this thread that was also told it was safe....nope.
I've been tuning motors for many years now and there are just to many variables to assume something will work. Monitor it first with your wideband at the very least for a few runs.
Sorry, he just thinks he knows more than he really does. Unfortunately, we can't divulge any tuning secrets just to appease his skepticism. The ECU can still pull timing - it doesn't need the low octane map to do it.
Divulge secrets? Open source = the death of secrets. And if anything, the maps I've seen from that camp give safe tuners a road map of exactly what not to do.
Are you trying to get me to LAUGH MYSELF TO DEATH?!? Because it might work.
Warr, you're out of your league in this discussion even more than I realized. Learn to tune yourself and reality will hit you like a ton of bricks.
But it wasn't severely lean. It was tuned into the mid-to-low 11s.
Yes, Noize, I can run the turbo to its max on race gas at altitude - it doesn't matter. It just doesn't make as much power due to inefficiency, but it doesn't randomly blow the motor.
Laugh yourself to death all you want, but there is a part of this you do not yet know. It's fine if you think that due to looking at Al's maps you think you know everything, but you do not. In fact, it's better that you think you do...please continue in that line of thought - it's good for us.
Sorry, Noize, but you really just don't get it. I do know how to tune myself and have done it for years. I choose not to mess with other people's cars, and I relinquish the reins to al for my own car, since he has more experience than I do, but I still know what's going on.
Originally Posted by 3volution8
off topic but you have buschur racing stage 5 i believe your sig said and your times are mid 12's?
Sorry to hear about the car.....if it went boom clank clank and wouldn't start that's definately a big motor issue. It won't clank without very bad things happening.
27PSI is alot of boost but it should be safe on 110+ octane. That is unless your car was damaged by poor tune prior to actually getting a professional tune.
What were your 1/4 speeds?
Originally Posted by drewblueeye
Well I took my car to the 1/4 mile track last night. put in 112 race gas, launching at the rev limiter and the clutch just touching then on the last yellow light launching WOT, best reaction time .071 worst reaction time .201
First run with 20psi of boost.....12.9 seconds, second run with 21psi of boost....12.7seconds, third run with 24psi of boost......12.5 seconds, fourth run with 27psi of boost..... BOOM!!!! CLANK CLANK CLANK CLANK CLANK CLANK... KNOCK KNOCK KNOCK KNOCK....GRIND....SHUTTER SHUTTER.... car died.... wont start.... Its not an intercooler pipe either. All i got to say is i did exactly what i was told by 2 companies (will not meantion whom)
Am taking the head off tomorrow and seeing how bad it is.
I know drag racing is fun....but on an overly hot day.....why even put your car through that kind of abuse? Especially since you pretty much know you won't pull the best slip you could.
Originally Posted by inco9nito99
8 sponsors, self-proclaimed "packages" running low 12's.
broke college kids working with scraps and running 11's with less invested....Nuff said :laugh:
