First time at the 1/8 dragstrip. How did i do??
Old Sep 20, 2006 | 02:06 PM
C6C6CH3vo's Avatar
A lighter wheel/tire combination will help with 60ft, mph, and maybe ET. As far as if it's signififcant - who knows until someone tries it. You can allways loose 0.2 seconds with a good set of shifts. I allways miss second.
Old Sep 20, 2006 | 05:16 PM
dbdude's Avatar
Two of the tires on my stock enkeis have little thread left on them. The other two tires are in great shape. Would this matter on a dragstrip since its already sticky?
Old Sep 20, 2006 | 07:42 PM
Warrtalon's Avatar
It matters if you are spinning. Are you spinning? If not, then it doesn't matter. It's common sense.
Old Sep 21, 2006 | 02:03 PM
dbdude's Avatar
Im spinning with my current tires. 235-40-18. Rev limiter is set at 6k. I think i might be dropping the clutch too fast.
Old Sep 22, 2006 | 07:18 AM
justchil's Avatar
You'll have better luck with a smaller rim even if it's the same weight... I spin like crazy off the line and still pull at least 1.75 60's. Your time is pretty decent considering the trap speed.
Old Sep 23, 2006 | 01:53 AM
ONRAILS's Avatar
I have lighter 18's than the stock wheels.. I went 12.8 on stock wheels. Cut a WAY better 60' with the 17's the car just seems hard to get going when on 18's. Rember I dont really have any engine mods. Just weight reduction and suspension
Old Sep 23, 2006 | 08:20 PM
justchil's Avatar
I found a timeslip of mine... I normally hit 4th gear and in this run I let off around 7600 in 3rd.
1.69 60' 4.86 330' 7.55@86.20
Old Sep 23, 2006 | 08:51 PM
dsmfan95's Avatar
Originally Posted by 05WhiteEVO8
How did you trap 89 with a stock catback? You have a 1.5 60 and NOS or something? That sounds like BS to me. With the mods in my sig I have gone 7.811@85 in the 1/8th (1.67 60) and ended up with 12.21@112.37. This was on the stock clutch though.
Question is how did you pick up 27mph in the back half with stock turbo?
Old Sep 30, 2006 | 11:13 AM
dbdude's Avatar
I went again to the track last night and i improved my times. The things i changed were, lowered tire pressure to 28psi from 35psi, dumped 2 gallons leaded 104 octane to my 2 gallons of 93 unleaded octane, and turned up the boost to 25psi. My previous best time was
60 ft 1.871
330 ft 5.415
1/8 et 8.369
1/8 mph 84.63 This was the best slip. All the rest ranged up to 8.6's that night.
My new best is
60 ft 1.853
330ft 5.312
1/8et 8.215
1/8mph 86.17
And i think i ran a 8.19 too. But the lady could not find my slip. I just cant get my 60ft to go lower than 1.85. Im gonna look into some drag radials for the stock enkeis.
Old Sep 30, 2006 | 11:16 AM
Warrtalon's Avatar
You don't need drag radials. You just need to learn to launch. There are cars that are far, FAR more powerful than you that cut 1.5-1.7 on regular street tires. Are you spinning or not? If you are, then lower the tire pressure more. You can't just pick a psi and go. You have to constantly tweak and change through the night until you find that optimum setting.
Old Sep 30, 2006 | 11:40 AM
SKILMATIC's Avatar
Hell depending on the track and tires I was wheel spinning at 25psi front and 26 rear on the stockers. Like warr said you have to constantly mess with your tire pressures.
Old Sep 30, 2006 | 11:51 AM
justchil's Avatar
What was the weather like? I raced yesterday at the local 1/8 and couldn't hook up at all.. It was around 45 outside... I couldnt hook up at all best 60' was 1.75 :\ If I had winter/all seasons 1.6's wouldnt have been a problem
Old Sep 30, 2006 | 11:52 AM
SKILMATIC's Avatar
Well thats a pretty damn good 60. The weather at mine is around 60-75.
Old Sep 30, 2006 | 01:21 PM
dbdude's Avatar
[QUOTE=justchil]What was the weather like?
It was about 80 degrees. My 2step is set at 6krpm. My rear tires are in good. My front are worn in from the inner area. These are 245-40-18. I do hear my tires squeel when launching. Next time i'll try lowering the pressure more. And i'll try the stock enkeis too. If that dont cut me a shorter time, then i think my 2step is set too high. I have read alot of you guys slip the clutch fast when launching. Some of you claim that when the evo barely moves forward, you drop the clutch. I have never been in another evo while being launched but i slip the clutch fast and have never had the burning smell.
Old Sep 30, 2006 | 03:28 PM
4G63Rules's Avatar
Proof that 18 inch wheels are for good looks, not good performance.
