First time at the 1/8 dragstrip. How did i do??
Old Sep 16, 2006 | 09:05 AM
dbdude's Avatar
I went for the first time ever to the local 1/8th mile strip to test out my evo. The track has a elavation of 600', it was 83 degrees, And a little windy against our cars. I had about 2 gallons of 93 and 2 gallons of 91. So i guess its safe to say i was running 92 octane. I did not cary the spare or jack. I just got a new exedy stg2 clutch installed a month ago. My wheels are about 22-23 lbs 18*8.5 on bridgstone potenzas. Everytime i used the launch control the tires would squeek bad off the line. Its set at 6krpm and builds about 5lbs of boost. Other cars their were bolton LS1's doing 8.9's and 9.1's repeatedly. All out extended bikes were doing 6.9's and7.2's. Full racing muscle cars were doing high 6's low 7's. Just for comparison. I wanted to buy race gas and bump the boost up a little but i'll do that next time. I repeatedly ran 1.85-1.88 60fts. Any advice.
Reaction 1.152
60 ft 1.871
330 ft 5.415
1/8 et 8.369
1/8 mph 84.63 This was the best slip. All the rest ranged up to 8.6's.
Old Sep 16, 2006 | 10:01 AM
dbdude's Avatar
11 veiws and no reply?? Come on guys.
Old Sep 16, 2006 | 10:16 AM
trevor's Avatar
Sounds like decent runs, I am guessing you would hit a mid 12 @ around 105-110 or so, but I am far from a 1/4 mi expert so I could be off. Seems like the conditions were far from perfect, and you may see quite an improvement with better fuel, less wind and cooler temps.
Old Sep 16, 2006 | 11:27 AM
dbdude's Avatar
Thanks for the reply. Maybe my launch control is set too high. Tires were squeeking bad. At one point i was trying to control the traction and get straight. Next time i will try race gas and bump the boost to 24psi. Check the tire pressure and lower it. I think i might go back to the stock gsr wheels for track runs.
Old Sep 16, 2006 | 12:41 PM
saywhen's Avatar
your launch was average at best, 1.87 is nothing to write home about. Easily could take a couple ticks of with a better launch. My guess is the 1/4 would be around 105 with a high 12 low 13. For me a 7.6 or 7.7 in the 1/8 at 90ish is a low 12.
Old Sep 16, 2006 | 03:18 PM
dbdude's Avatar
Yeah im guessing high 12 low 13 too. I think i can get a better launch next time. Possibly a high 1.7.
Old Sep 16, 2006 | 07:57 PM
AlwaysinBoost's Avatar
I'm guessing high 12s also. the launch isn't bad but there is some room for improvement.
when I run mid 12s my 60' is usually 1.7, the 330 is 5.1x-5.2x and the 1/8th is 8.0x-8.1x with 85-86mph trap. more practice and you'll get there. Overall not bad for your first time out.
Old Sep 17, 2006 | 08:16 AM
dbdude's Avatar
Thanks. When you get that 1.7, do your tires spin?
Old Sep 17, 2006 | 09:57 AM
nope, I haven't ever got wheel spin.
Old Sep 17, 2006 | 01:35 PM
saywhen's Avatar
There is a little tire squeal on my best launchs, I have spun the tires out of the hole and it can be scary when the car rotates. It could be cold track temps, poor track setup or water on the tires.
Old Sep 19, 2006 | 04:01 AM
ONRAILS's Avatar
i went 8.4 in the 1/8th and finished 1/4 at 13.2 but i dont have the topend you do im sure.. i'm stock
Old Sep 20, 2006 | 04:42 AM
C6C6CH3vo's Avatar
I ran 8.034 @ 89 mph my 2nd time out to strip with close to same mods as you last year.
Only difference was custom dynoflashed on 93 oct with stock catback, no launch 2step, and stock clutch.
This was on 23 psi on 93 octane (custom tuned)
Expect a lot faster times with more octane and boost, but tuning for that will make the most difference
Old Sep 20, 2006 | 05:17 AM
05WhiteEVO8's Avatar
How did you trap 89 with a stock catback? You have a 1.5 60 and NOS or something? That sounds like BS to me. With the mods in my sig I have gone 7.811@85 in the 1/8th (1.67 60) and ended up with 12.21@112.37. This was on the stock clutch though.
Old Sep 20, 2006 | 05:52 AM
C6C6CH3vo's Avatar
Originally Posted by 05WhiteEVO8
That sounds like BS to me..
Timeslip says 89 mph
Want me to mail you the piece of paper?
89mph? - 245 45 17
Edit
I have my peices of paper here to update my memory:
Virgin run (1st time) 10/30/05
1.829
8.437 ET
83.6mph
2nd outing (new tires, and 10.5 HS added)
1.798
8.045 ET
88.739mph (your right, I BS'd, I was 0.2mph off)
Old Sep 20, 2006 | 01:44 PM
dbdude's Avatar
Do yall think i have a better chance at a faster 60ft with the stock enkeis over my heavy 18's? These rims weigh about 22lbs each.
