went to the track....need help with 60fts
Old Sep 16, 2006 | 05:39 PM
thekuai's Avatar
brand new bf goodrich drag radials on kosei k1-ts......6000 rpm 2step....i go WOT while staging....
Old Sep 16, 2006 | 06:16 PM
IEXCELR8's Avatar
What pressure did you run?
Old Sep 16, 2006 | 06:17 PM
thekuai's Avatar
started the day with stock tirerack pressures......37psi......graduallly dropped to 15 psi...not much change...
Old Sep 16, 2006 | 06:19 PM
IEXCELR8's Avatar
Were you spinning or slipping the hell out of the clutch?
trap looks good for 11.35 with a 1.65 60ft.
Old Sep 16, 2006 | 06:20 PM
thekuai's Avatar
it was spinning.....let it pretty fast but not dumped
Old Sep 16, 2006 | 06:23 PM
IEXCELR8's Avatar
Back off on the 2 step to 5k-5500 and see if it helps.
How many runs did you get in? What was your best 60ft?
Old Sep 16, 2006 | 06:25 PM
thekuai's Avatar
i got in 5 runs.... best 60 was 2.045....worst was 2.112
Old Sep 16, 2006 | 07:52 PM
AlwaysinBoost's Avatar
wow that is one hell of a trap for 27.5psi... get that 60' down and your car is going to run a mid-low 11.
Old Sep 17, 2006 | 01:32 AM
Ang Wen Yan's Avatar
How you launch??Slip or dump?
Old Sep 17, 2006 | 11:14 AM
thekuai's Avatar
let it out quick...but no dump.....no clutch smell
Old Sep 17, 2006 | 11:21 AM
DCSilvrEvo's Avatar
Try to let slip a little more. Like just a little. I will let the car start rolling and then let the clutch out quick and i get consistant 1.70 and below. Also try doing a burn out but make sure all for wheels get in water or u might end up breaking something.
Oh BTW I have some Azenis AutoX tires and i have the pressure @ 20Psi in from and 25 in the rear.
Old Sep 17, 2006 | 11:28 AM
1BlackEvo9's Avatar
I had the same trouble with my 60's and I'll tell you what everyone told me practice, practice, practice....
Old Sep 17, 2006 | 05:52 PM
Evo_Jay's Avatar
Damn, your car only weights 2750.
Old Sep 18, 2006 | 01:42 PM
2StepsAhead's Avatar
I say this and thekuai doesn't listen, now someone on the board says it and hes going to listen...kids these days, I tell ya...
myevostore.com
Evo 'For Sale' Miscellaneous
Mar 11, 2005 12:15 PM
gabesir
Jan 25, 2005 03:31 PM
4drbike
12
Jun 8, 2004 02:48 PM
