Second Time at the Track Ever! Much Happier =)
Old Nov 24, 2006 | 07:09 AM
9t1tsi's Avatar
Originally Posted by EvoRecordSetter
since when was 12.6 fast ***? lol
people run 12.5's with TBE and a tune.
even a 13.0 with a 91 vr4 galant with tbe and 16g, with fmic
Old Nov 24, 2006 | 07:17 AM
MalibuJack's Avatar
I have falken tires on my car.. I'd get alot of wheelspin on a poorly prepped track, And I'd get my front right wheel spinning (03 with no front LSD) in second with similar basic mods I had made early on.
Your times are right along the lines of what to expect with those mods.. I'm not sure about the rev limiter in 4th, but you do say its an MR (6 speed correct?)
I used to hit the rev limiter at 7650 RPM in 4th as my traps started getting faster and I was running a few mph higher..
Old Nov 24, 2006 | 02:05 PM
C6C6CH3vo's Avatar
From the mods posted I would say the IX is capable of exceeding traction threshold upon 2nd gear acceleration, I would moreover say the car can be capable of much faster times.
Even my stock turboed 04 SSL (SSL=slow) will break loose from a 1st gear roll and is not very far, wtqwise, from having that happen in 2nd. Many things aside from WTQ and H2O lessen traction, tire pressure.
When you get the other turbo you might solve your tire spin but in any case, if your track uses alot of water for muscle brained RW burnouts, use them yourself but make sure all tires are wet!
Hey Jack, got any old track times you can find?
Old Nov 24, 2006 | 03:09 PM
Pure Playaer's Avatar
well all he had was a tbe drop in n custom flash he did himself, inwhich he supposivly tuned mivec..
Old Nov 24, 2006 | 03:11 PM
Originally Posted by STISTL
Track prep at Moroso sucks. Thats why you were spining you tires in second gear.
see i was thinking this also..
wednesday night, there was lots of fluids on the track from people breaking trannys left and right.. and i was there for about 3 hours because people were losing control right where i was basically shifting to 2nd.. and crashing.. some corvette crashed that night in just about hte same spot..
so you never know
Old Nov 24, 2006 | 03:14 PM
yea moroso is supposivly a very badly preped track, half the time i hear they dont even spray water down or w/e for the people who burn out..
yea i have n mr, and it seemed as thou i was CLOSE to the rev limiter, althou i was not hitting it..
So it wasnt just my craziness telling me im spinning in second, it is actually possible.
thanks for the help!
Old Nov 24, 2006 | 08:24 PM
SKILMATIC's Avatar
Much better but more room for improvement. I ran a 7.7 1/8mile with a trap of 90mph with a tbe, o2 housing, drop in and flash. Keep preacticing your luanch and shifts.
Old Nov 25, 2006 | 07:44 PM
Mooseknuckle's Avatar
Definitely room for some improvement. Went today and I have only a cat-back with test pipe, reflash, and drop in filter...ran a 12.63@107. Work on that shifting cause I had a similar 60 ft of 1.8.
Old Dec 10, 2006 | 08:14 PM
Big Dube's Avatar
hey pure player i was there on the 22nd i ran a 12.66 @109 with just a turboback and a flash.
