First time at track...slightly dissapointed
Old Dec 17, 2006 | 05:03 AM
dustink's Avatar
Old Dec 17, 2006 | 05:18 AM
KawRider's Avatar
Pratice will make it a little faster. The launch/60 ft is where you can pick up the most time. search for launch techniques here in the Drag racing forum. the MPH seems about right for lightly modded EVO. I think you will get a 12.8 or 12.9 next time if you get a good launch. Good luck and keep us posted.
Old Dec 17, 2006 | 05:23 AM
mcwop23's Avatar
it seems like your car falls on its face after the 1/8th
Old Dec 17, 2006 | 05:39 AM
tuning g's Avatar
I theink your car may be pulling timing up top because run 2 was better than 1 but the mph is lower and a little off but a 1.6-1.7 60 ft will net you a 12.65-12.73 @107.50 mph thats if its not pulling timing because the boost should be stable up top in 4th the best way to check that is to add a little race gas just to see what happens like under 1/4 tank pump and 2-3 galons for 100 oct and watch the mph to see if its goes up.
Unless you can doo a datalog and check for knock then you would know whats up
Old Dec 17, 2006 | 08:35 AM
Nad1370's Avatar
Boost?
Boost at 7K rpm's?
Shift points?
Old Dec 17, 2006 | 09:01 AM
dustink's Avatar
Old Dec 17, 2006 | 02:56 PM
Nad1370's Avatar
Definately low traps for the mods and high boost. Should be easy 107+mph. 1/8 mile traps look low also.
Ever did a boost leak, plugs, comp. check, ect....
Timing might be getting pulled but no way of knowing without logging. Was it sputtering/cutting out during 3rd and 4th gear ?
25 psi? I'm pretty sure your not tuned for it on 93oct.
What boost were you tuned at? Any idea what your AFR's at?
Old Dec 17, 2006 | 07:29 PM
dustink's Avatar
File Type: txt
Old Dec 17, 2006 | 07:31 PM
TTP Engineering's Avatar
Only 2 runs was a waste, especially after $20 in racefuel and not having enough time to cycle through the fuel system.
Next time you are in that position, take the car out of the dragway and make a few passes on the street to get the high test pumping through prior to running again.
With only 2 runs, with crappy launches I would say that there is not enough data to support any verdict.
The car already shows 12.8 with a good launch. I am interested to see your are able to make 4-6 passes the next time out so we have enough data to analyze.
I had a customer last Fri run a 12.6, then out of the blue run a 12.3 on pump the next pass. Its all about a chain of events working in harmony from launch, to shift RPM to shift speed and so on.
Originally Posted by dustink
Went to Bradenton Dragway yesterday and managed to get 2 runs in. It was overcast, not too hot, but I'm sure the humidity was high. Dissapointed that I did not get into the twelves but more concerned with my trap speeds. I would think with my mods they would be higher.
2005 Evo RS
MODS:
TBE
Megan manifold
Megan 02
Hallman MBC
Fuel Pump
KN drop in
TTP Custom Tune
Stock Clutch and Stock 5000 rpm 2-step
RUN 1:
60': 1.918
1/8: 8.354
MPH: 82.75
1000: 10.904
1/4: 13.020
MPH: 105.57
RUN 2:
60': 1.887
1/8: 8.376
MPH: 83.48
1000: 10.948
1/4: 13.075
MPH: 104.62
Please feel free to critique, offer suggestions, etc. It feels like the car might be pulling timing in 3rd and 4th. I added 110 leaded after the first run but I don't think it had a chance to get to the injectors for the 2nd run. I had 1/4 tank 93 when I added the race gas.
Dustin
Old Dec 17, 2006 | 07:33 PM
vito1's Avatar
Just work at it and youll be str8...
Old Dec 19, 2006 | 04:44 AM
USAF_STi's Avatar
Your trap speed is low for your mods. I trapped that in my stock 2005 evo 8 with ssl. Like someone said it looks like you are pulling timing up top. I think that 25 psi is a little high for pump gas as well which would explain you pulling some timing.
Old Dec 19, 2006 | 04:29 PM
Mivecless's Avatar
25psi is the spike, not the boost on the top. There are many tuners that tune for 26psi spikes, especially on Evo IX with longer plugs (anti detonation quality).
If a tuner adjusts the ignition timing according to the boost level, you could run 30psi if you wanted to on pump with no knock.
Those are the facts.
Old Dec 19, 2006 | 04:49 PM
freddiet's Avatar
Where's Warrtalon??
Old Dec 19, 2006 | 06:40 PM
Mivecless's Avatar
Originally Posted by freddiet
Where's Warrtalon??
In the 12's on alky and cams from what I hear.
Old Dec 19, 2006 | 06:53 PM
pac74's Avatar
so you ran race gas without the car reading it? or a base flash picks it up?
