who is still running thier stock clutch?
I had 18K miles on my 05 VIII's stock clutch when I had my car tuned on race gas and made 322whp on a mustang dyno. I drove another 2K miles and a bunch of 6 thousand RPM 2 step launches and my stock clutch held up pretty well. I even launched back to back to back one night on race gas and my clutch still didn't go to crap, it just smelt like it for about 15 min. I guess I got one of the good ones.
If you are going full throttle when you release the clutch then it will go sooner, you need to roll into it when you slip the clutch.
the stock clutch can last for a while if you don't beat on it.
like mentioned above by fimotorsports let the clutch cool down after every pass. I had my stocker last around 100 passes and 30k+ miles before I put my twin disk in.
what eventually killed my stock clutch was doing 6 hot lap drag passes with low 1.7 - 60's and no cool down time. On the track the clutch still would grab fine, when I left the track on the highway in 5th gear it was slipping bad.
with practice you can get some good 60s on the stocker, then when you upgrade you'll be that much better on your new clutch.
39,000K on my 05 RS still stock clutch, I do not launch the car, I shift pretty quick tho, otherwise it would take a **** for sure. 4-5 hard launches with my mods. So (After winter iam getting new clutch tho)
I've got a little over 40K on my car and it hasn't slipped once. I don't race the car and only launch hard on occasion. Car has basic bolt-on's and like 290WHP. I hope it lasts a bit longer!
Im on the stock clutch at 41K miles. Launched once or twice no 2 step. Tuned with SAFCII and got some bolt ons. clutch still grabs hard and hold the power all day every day almost as good as day one
