Same full weight Evo IX goes 121.66 mph
Old Apr 9, 2007 | 07:03 PM
  #31
EVOVIII200's Avatar
that is goes to show you, those evo ix's don't really need a bigger turbo, just the right set up. very strong evo, congrats!!
Old Apr 9, 2007 | 07:08 PM
  #32
EVOVIII200's Avatar
also did you use 280/280 or /272/272 cams. most of the time you hear 280's get you high top speeds.
Old Apr 9, 2007 | 07:40 PM
  #33
kouzman's Avatar
He said Cosworth cams... Thats 272/272 11mm lift... there is only one type!
Crazy trap indeed...!!! Congrats...
Now that you said the tire dimension i see from where you found the extra mph trap!
Good Job...
Old Apr 9, 2007 | 11:40 PM
  #34
Illrunya's Avatar
props dude!
Old Apr 9, 2007 | 11:57 PM
  #35
fromWRXtoEVO's Avatar
Originally Posted by RUELASEVOIX
I'm passing the 1/4 mile in fourth gear. The reason i'm not lowering the E.T.'s is because i'm still spinning a little bit in the 60's, like i said i'm going to try in another track and lower more the tires pressures and see what happens. I which i can go 1.58-1.60' and break the local record 11.44 sec made by an Evo 8.
thanks everyone,
LF Ruelas
You are crossing in 4th gear at 121mph on a MR? what is your red line bro?
By the way, phenomenal times!!
Carlos
Old Apr 10, 2007 | 05:09 AM
  #36
3000ways's Avatar
Originally Posted by 4 Wheel Slide
his launch is fine.... who are you to say not perfect lol
anything below 1.75 isn't bad...
last i checked u were pimping 1.9's and 2.0's
have you broke 12's yet? probably not lol why do you always need to say something negative
Nice run man!
cheers!
Dude chill It was not my intentions to sound negative, did you actually read my post or did you stop at not perfect? Also when do I post negative sh*t??? Perhaps you have me and warrtalon mixed up (although I admit when it comes to the STI I am pretty negative).
Old Apr 10, 2007 | 05:12 AM
  #37
3000ways's Avatar
Nice run man!
cheers!
Also I was just wondering why his E.T. didn't go down, his previous 11.5@117mph was with a 1.75 60ft and he had a 1.69 and 1.70 60fts for these runs, and I was just wondering why his E.T. didn't go down? Didn't know it was a f*cken crime to ask a question. Sh*t I was the first one to give props in this thread or did you miss that one too
Old Apr 10, 2007 | 05:14 AM
  #38
bigric09's Avatar
Carlos
he said GSR
Old Apr 10, 2007 | 08:27 AM
  #39
Originally Posted by bigric09
he said GSR
Good catch! the lack of reading the whole post and the MR rims played a deceiving factor and unprecise opinion on my side.
Carlos
Old Apr 10, 2007 | 08:30 AM
  #40
Kc2Buk's Avatar
Nice numbers!!!
Old Apr 10, 2007 | 08:34 AM
  #41
thatguy's Avatar
Carlos
9's have much shorter 4th gear.
I wasn't even aware that 121 mph was even able in 4th gear at 8000 rpms.
Old Apr 10, 2007 | 08:35 AM
  #42
thatsMR2u's Avatar
you can trap 121 with rev limiter set to 8100 in 4th gear in a MR- hmmm intresting
Old Apr 10, 2007 | 08:45 AM
  #43
Blue Evo 8's Avatar
My tires are 245/45 R17 Nitto drag radials and i'm passing the 1/4 mile at 7800 rpm. Yes my rev limit is set at 8000 rpm.
LF Ruelas
Humm....i wonder if I can hit 126-128 Traps with my added mods and a tire change?
Old Apr 10, 2007 | 09:16 AM
  #44
kouzman's Avatar
i used a calculator to see the max speeds at a 7800 rev limit and a 8000rpm rev limit in both stock dimensions and bigger dimension tires...
7800rpm limit
1. 235/45-17 = 118 mph
2. 245/45-17 - 120 mph
8000rpm limit
1. 235/45-17 = 121 mph
2. 245/45-17 = 123 mph
Definitely is doable on the IX
Old Apr 10, 2007 | 09:20 AM
  #45
Blue Evo 8's Avatar
7800rpm limit
8000rpm limit
Kouzman,
do you have a link to the calculator?
