First time to the track with the 35r
Old Apr 26, 2007 | 06:33 PM
rACerS's Avatar
I headed out to Sacramento Raceway last night to try and get a couple of shakedown runs in with the new setup. I had a blast and just couldn't be happier with the results. Keep in mind that this was done on the stock clutch and wheels and tires.
I got to make 2 passes and then they asked me to hit the road. The first run I didn't know what to expect, so I only let the car build about 5psi on the 2 step and let it rip. I was rewarded with a big fat bog. I was expecting to be smashed into the seat, but instead I was almost slammed into the steering wheel And then it felt like an eternity until the turbo finally spooled up. I ended up missing 4th and ran a 12.0 @ 120mph w/ a 2.1 60'.
For the second run I sat on the 2 step until I saw 15psi and dropped the clutch. The car left on boost this time and I ended up spinning all the way through first. The car was pulling insanely hard. I had a clean 1-2, 2-3, and 3-4 and then had to hit 5th about 300 feet from the finish line. The car dropped out of boost in 5th and didn't start to spool back up until I was rolling through the beams So the car wasn't accelerating at all for the last 300 feet, so I was just cruising along.
And here's the slip
As you can see I only gained 20 mph on the back half. And on the first pass since I didn't hit boost until about quarter track I was able to run through the traps in 4th and it gained 31mph on the back side with a missed 4th shift. So I'm pretty sure that with a clean pass and an evo 8 4th the car should mph in the mid 130's. But then again who knows.
Thanks to everyone for the support.
AND A HUGE THANKS TO ANDY, without him this wouldn't have happened.
and hopefully someone got a vid of the second run
Mods:
Shearer 35r kit
Cosworth cams w/ HD springs
buschur ic piping
AEM EMS
1000cc injectors
walbro pump
3" tbe
26psi
104 unleaded
Old Apr 26, 2007 | 06:50 PM
homiusang's Avatar
Man, that's definitely moving! Time for better gears and a cage!
chrisblueevo's Avatar
wow. Is that a stock motor
Old Apr 26, 2007 | 06:59 PM
evovin's Avatar
stock blocke right? do you have stock rod bolts too?
Old Apr 26, 2007 | 07:16 PM
rACerS's Avatar
Stock bottom end
Old Apr 26, 2007 | 09:55 PM
silverofs's Avatar
wow nice pass man that is awesome!!!!!
Old Apr 27, 2007 | 05:33 AM
94AWDcoupe's Avatar
Thats really quick car for mod list. 104 in 1/8 is fun.
Old Apr 27, 2007 | 08:19 AM
05WhiteEVO8's Avatar
Nice run. What clutch are you running?
Old Apr 27, 2007 | 08:31 AM
milo's Avatar
Awesome trap speed in the 1/8th mile..........actually nice time and trap considering it was your first time with this setup.
Just imagine if your ran 30psi of boost, that thing would be very scarey.
Old Apr 27, 2007 | 08:36 AM
Ultimate CC's Avatar
man that thing is moving...
Old Apr 27, 2007 | 08:38 AM
kmcconn9's Avatar
impressive..
Old Apr 27, 2007 | 08:39 AM
EVOB23's Avatar
Nice run!
Old Apr 27, 2007 | 08:45 AM
Blue Evo 8's Avatar
I wonder if I can go 10's with a 1.7X 60' time or less?
Old Apr 27, 2007 | 08:47 AM
precisi0n's Avatar
Great time... I need to get to the track on a cool night to see if I can match that. Great driving!!!
Old Apr 27, 2007 | 08:51 AM
project VII's Avatar
damn nice time
