How many lbs. of boost @ launch?
Old Apr 29, 2007 | 09:03 AM
groove304's Avatar
How much boost are you guys hitting when launching? I am only building a few pounds when I'm bouncing off the 5,000 rpm 2step. And I am holding it at the line. Is this normal? Can this be changed after I get the car flashed? It's also dropping off as soon as the clutch is fully released which is killing my 60 ft time.
Old Apr 29, 2007 | 09:08 AM
Nez136's Avatar
14psi@5800 rpms. The flash will help
Old Apr 29, 2007 | 02:52 PM
groove304's Avatar
How? From the flash and mods? I'm basically stock. Should I only be boosting at 4 psi when launching? I can't get it to go higher.
Old Apr 29, 2007 | 02:57 PM
PlanoEvo's Avatar
Are your keeping the throttle floored or just holding it at 5000 with slight throttle? What 60ft times do you get?
Old Apr 29, 2007 | 02:58 PM
groove304's Avatar
floored... bouncing
Old Apr 29, 2007 | 07:38 PM
evovin's Avatar
mine is 5400rpm and boosting around 12-13 psi! no tune
Old Apr 29, 2007 | 07:40 PM
Clutchdc5's Avatar
12-13 @ 6100rpm
Old Apr 29, 2007 | 11:15 PM
groove304's Avatar
Why would mine be so much lower? I'll just go ask the Mitsu dealership tomorrow... "Why aren't I boosting when I launch the car at 5 grand?" lol
Old Apr 29, 2007 | 11:28 PM
drano7823's Avatar
Mine is 10-11 psi and 5500..........Jestr flash
Old Apr 30, 2007 | 07:33 AM
FastAzzEvo's Avatar
mine is between 12-13psi 6K
Old May 1, 2007 | 03:51 PM
groove304's Avatar
ttt. Can someone answer why I'm not boosting as high off the line? Is that about normal for an unflashed IX?
Old May 1, 2007 | 05:03 PM
PlanoEvo's Avatar
Does the flash raise the boost at launch by just raising the rpm? If so how much so an IX expect at the 5K factory limit?
Old May 1, 2007 | 05:05 PM
tarmac4g63's Avatar
mine is like 9psi at 5600
Old May 1, 2007 | 05:10 PM
Cali2MDevo8's Avatar
Registered User
maybe your boost gauge is not correct? Take it to the track and look at your 60' times
Jason
Old May 1, 2007 | 09:32 PM
groove304's Avatar
Jason
I've got a defi boost gauge. It's dead on. Pulls 19 psi stock.
