How many lbs. of boost @ launch?
Old May 2, 2007 | 11:09 AM
FastAzzEvo's Avatar
before i had a tune I didn't not run that much boost at 2 step, don't know why, maybe something to do with being so rich or maybe something to do with the timing or mivec maps on a stock car.
Now with a flash I'm boosting more off the line.
Get a flash you will probably see an increase, of course you might not boost much at a lower 2step rpm. Again mine is at 6K
Old May 2, 2007 | 11:17 AM
v8hater's Avatar
The reason why your not boosting as much as the rest of us is because all of the posters have raised the launch control via flash. Thus if you raise yours too you will see more boost when launching.
Old May 2, 2007 | 12:38 PM
C6C6CH3vo's Avatar
1.72's launching at 6000 RPM, NO boost (still vacume) with Excedy S1 clutch and ported (not removed) hydraulic restrictor.
I don't use rev limiter for launch - it makes my car retarded from stationary knock and also I can't afford new transmissions at this point
Old May 2, 2007 | 12:42 PM
Nez136's Avatar
Originally Posted by groove304
How? From the flash and mods? I'm basically stock. Should I only be boosting at 4 psi when launching? I can't get it to go higher.
Well i have a built motor with a larger turbo, so pulling a little more timing on the 2 step wont hurt.
Old Sep 26, 2007 | 01:55 PM
frost318's Avatar
Just b/c the boost gauge is saying you are boosting 19psi does not mean it is accurate. I had a leak on one of my boost lines, and i thought it was reading right at the time. It was showing 22psi and when i did a boost leak check it wasnt even hitting 20psi.
tstevens
11
May 1, 2012 01:11 PM
lanberg
Apr 22, 2012 12:03 AM
Billy05MR
14
Jun 17, 2010 10:20 AM
Raceghost
Apr 24, 2009 09:50 PM
ksuchewie
Nov 25, 2007 10:13 PM
