How do you set your launch boost?
Old Apr 2, 2009 | 09:51 PM
Raceghost's Avatar
I may not know exactly what it is called, but I am looking for a quick how to on setting my launch boost, so when I am idling at the line. I have heard you can set it to any RPM for the the launch. Supposedly when you hold the clutch, push the pettle, it revs to a certain amount, and the rev limiter sets in and holds it so you can build boost?
Someone straighten me out please, oh, and where do I set it in the ECU?
Thanks guys in advance.
Old Apr 2, 2009 | 11:03 PM
xspsi4's Avatar
You will need to get it flashed in order to do that or you can buy the cable and ecu flash and do it yourslf.
Old Apr 3, 2009 | 12:56 AM
Raceghost's Avatar
Yes, I am aware of this. I have the cable, and the software, just not sure where or what table it is in. Thank you but please clarify.
Old Apr 3, 2009 | 01:06 AM
kaymin's Avatar
Its the stationary rev limiter....
Doesn't sound like you want to mess with too much stuff in your ecu though......
Old Apr 3, 2009 | 01:08 AM
kaymin's Avatar
oh and you can't really control the amount of boost it builds since there isn't any load really on the motor. You kind of just get what you get.....
Old Apr 3, 2009 | 01:11 AM
RICAN RED 4G63's Avatar
Yeah proper term would be 2 step! And like kaymi said i wouldnt mess around with your ecu too much unless you really know what your doing!! Good luck to ya!!
Old Apr 3, 2009 | 01:21 AM
Raceghost's Avatar
yah, just wanted to set that is all. I am getting a tune soon, but need to make some adjustments currently. I am sure that any custom tune sets this correct?
What is a safe setting for this utilizing stock drive train but possible light weight fly, with ACT street clutch, 21 pounds of boost...?
Old Apr 3, 2009 | 01:33 AM
kaymin's Avatar
5.5k is what mine's at
Old Apr 3, 2009 | 03:09 AM
onboost's Avatar
5.5k is all you need. if you cant win it from there then hmmmmmmmm
Old Apr 3, 2009 | 08:25 AM
Raceghost's Avatar
thanks guys. wasn't sure if I needed to adjust this setting for parts, like the custom tune, or if it was a straight weight setting.
Old Apr 3, 2009 | 09:40 AM
sti.this's Avatar
some of the guys around here have decreased timing in the rpm/load cells that you are in while on the 2-step and gained a pound or two. The most youre going to get is 15psi or so with the factory hardware.
Old Apr 3, 2009 | 09:59 AM
SPEEDPIMP's Avatar
Give "Dapper Dan" a PM on here he can get ya set up FO Sho
Old Apr 3, 2009 | 10:02 AM
inco9nito99's Avatar
Like aforementioned, you can decrease timing at the load cells where you're activating your two-step and that will allow for 3-5psi more than OE. Do some logging to figure out exactly where you're at.
Old Apr 5, 2009 | 11:02 PM
C130flyer's Avatar
I wouldn't worry too much about the two step hurting your car, it's that left foot and how hard you drop the clutch that could hurt it.
Old Apr 5, 2009 | 11:40 PM
kaymin's Avatar
I've only two stepped hard twice and both of them were softer feeling on the drive train and pulled harder then regular launches i've done. I love 2 step.
Just hold the gas and pull the clutch out slowwww till you feel it engage, hold it there till you wanna launch and then let it out from there like you would a regular shift, not slow, not fast. I lit up my 265 tires yesterday and was totally not expecting it!
