How do you set your launch boost?
Old Apr 24, 2009 | 08:17 PM
  #31
sktng22's Avatar
id bring it to someone who knows wat there doing! i got my car tuned by ivey and its a totally different car then before. he set the 2 step so much higher then stock. makes a big difference
Old Apr 24, 2009 | 09:50 PM
  #32
GRNCT9A's Avatar
Originally Posted by Chabada15
nope but you can snap an axle or blow a transfer case with less
also, changing the timing in those maps would absolutely effect the rest of your driving, especially if you road race or autocross, since letting off the gas at 6k and then getting back in it would cause the car to unload then reload the engine, causing the map to read below the 2-step set rpm/load point then going thru it when hitting the gas again since the load will increase, it will cause knock if not watched closely
Yea, you might break something. There are countless people on here that 2 step their cars with 10+psi and haven't broken anything.
I am still waiting for someone to blow their engine up with 2 step timing load retarded low. The ecuflash gurus do it and alot of tuners. Untill someone says and shows this is bad for the car, I will continue to do it and encourage others to do it as well. If they know what they are doing.
xBoostx
Oct 7, 2016 01:47 AM
GreeceS13
May 26, 2015 10:01 AM
AOR
Driving Techniques
40
Feb 2, 2007 03:44 PM
11SECEVO
Sep 23, 2006 12:57 PM
