Launch control boost experiences
Old May 26, 2015 | 01:24 AM
GreeceS13's Avatar
Tell me about your launch control boost experiences..
How much psi do you suggest me to launch with GT3582R?
Just rev limit like stock isn't good choice? With stock turbo I had very good success with just rev limit.
My whole engine is stock so I don't want to strees it very much with high boost launch..
Old May 26, 2015 | 06:46 AM
badev0's Avatar
I usually run very little boost with higher RPM, about 5lbs or so. I usually cut high 1.4 60's. Too much boost I'll just blow the tires loose and hurt the 60'.
I have not tested with lower rpm/more boost yet.
Old May 26, 2015 | 09:48 AM
GreeceS13's Avatar
10.01sec stock block? You are my future :P
Stock turbo with just rev limiter at 6000 around I had boost 5-10psi and I had very good 60' with 17" radials.. 1.6!!
Now I will run with 15" slicks (26-8.5-15)!
I will try your method! What turbo are you run? How much rpm do you launch it? Tire pressure?
Old May 26, 2015 | 10:01 AM
badev0's Avatar
Thanks
I am on a PTE 6262, 15" Hoosier QTP's, and launch around 6-6400 depending on track conditions.
moreno78065
Jun 18, 2015 07:20 PM
turbor850
Mitsubishi TC-SST Discussion
29
Dec 29, 2009 10:03 AM
R1ckyB0bbyyy
Driving Techniques
Feb 4, 2008 10:58 AM
jasburbak
May 20, 2007 09:08 PM
