Question for building boost on 2 step launch control
Old May 20, 2007 | 12:54 PM
jasburbak's Avatar
I got tuned by Al a couple weeks ago, and had a chance to run at the strip 2 days ago: I just have a quick question for those who use a 2 step launch control.
When i am bouncing off the rev limiter, i am not building any boost (i though we were supposed to get ~10psi - variations for individuals though)
My method is, depress clutch in all the way, 1st gear, then slowly press the gas till it starts bouncin off the rev limiter @ around 5750 (but not all the way down). If i go wham on the gas pedal instead of slowly pressing it'll rev till 7800rpm
I just tried pushin the gas pedal down a bit more this time (a few minutes ago) and the car started bouncing off the rev limiter much harsher and harder, but i started to build 5psi..
Question is: Should i press the gas pedal all the way down (or at least further, till i read 10 psi before i launch) or will this start hurtin the car more?
Oh, and i ran a 12.6 @ 111.3 w/ a 1.9 60ft time... i could do better i believe with that trap speed, but damn 3rd gear grind, and well a better 60ft....
Comments?
Thanks...
Old May 20, 2007 | 01:05 PM
scheides's Avatar
EvoM Moderator
Yup, hold the pedal to the floor!
Old May 20, 2007 | 01:16 PM
Clutchdc5's Avatar
evo8
I don't think evo8's have 2steps. You gotta get it flashed
Old May 20, 2007 | 01:20 PM
mcwop23's Avatar
he said he got tuned by Al
Old May 20, 2007 | 01:22 PM
mack4477's Avatar
his first lines stated that he got tuned by Al (dynoflash).
and what i do is i rev twice first. first time to 4k~ish, second to 5k~ish, then floor it. bounces off 6k, and i usually get about 10-12 psi. not sure if its the best way, but it works for me
Old May 20, 2007 | 02:32 PM
Warrtalon's Avatar
The whole point of the 2-step is for launching at full throttle. It doesn't work if you're not at full throttle. You just floor it and sit, then work the clutch when the lights come down.
It's not even important how much boost you build, because you can easily launch without a 2-step. People get too hung up on how much boost they see on their boost gauge while using the launch control, but it's not an issue. You should be worried about how to properly modulate the clutch in order to hit good 60's.
Mack, there is no reason to rev twice or whatever you do. Just mash the pedal and go - it won't change how much boost you build on the launch limiter. The amount of boost is determined by RPM you choose.
Old May 20, 2007 | 03:33 PM
mack4477's Avatar
not saying that i build more boost doing it that way warr. just sounds, to my ears, like it may be a little easier on the engine. as long as i get some boost, i'm good
Old May 20, 2007 | 03:37 PM
mcwop23's Avatar
i stage first and start revving as soon as the other car stages full-throttle. Seems to work well.
Old May 20, 2007 | 05:55 PM
FL_SilverEvo8's Avatar
agree
Old May 20, 2007 | 07:03 PM
Paul Nelson's Avatar
Ive part throttled my stock turbo and cut 1.6 60ft no problem its all on how you slip the clutch. Ive even done it on my big turbo and cut 1.7 60ft times
Old May 20, 2007 | 07:39 PM
jasburbak's Avatar
Thanks for the help guys, much much appreciated, and thanks Warr as well.
I got a 1.68 60ft time when i had only a catback on when i first got the car, so i'm relating my last runs to almost bald advans and not a well prepped track as an excuse for now
Old May 20, 2007 | 09:08 PM
uglyevo's Avatar
pedal to the metal
xBoostx
Oct 7, 2016 01:47 AM
mrmiller
Mar 14, 2016 04:06 AM
jrsimon27
Mitsubishi TC-SST Discussion
28
May 4, 2010 08:24 PM
crewdawg130
Jul 9, 2009 07:01 PM
R1ckyB0bbyyy
Driving Techniques
Feb 4, 2008 10:58 AM
