New personal best
Old Apr 30, 2007 | 11:07 AM
2.3 Evo 8's Avatar
New personal best
Went to Import Showdown ready to run VP import and 31 psi, but after making a couple passes we realized something was wrong. I could only run 24 psi. We switched my perrin controller with a manual controller and the same 24 psi. I tried turning the controller both directions but it would stay at 24 psi no matter what I tried.
Oh well, on to the good news.
11.1 @ 123 mph 1.62 60'
I ran numerous 11.1 @ 123 mph with my 60' in the 1.62 - 1.66 range.
When I have time I will try and figure out what is causing the boost to be so low.
I should have a video up by the end of the week.
Old Apr 30, 2007 | 12:00 PM
mike1023's Avatar
what is done to the car
Old Apr 30, 2007 | 01:33 PM
DRAG's Avatar
Congrats! Can you post the entire slip?
Old Apr 30, 2007 | 04:28 PM
evo3matt's Avatar
good job phil, def should have won modified
Old Apr 30, 2007 | 05:20 PM
2.3 Evo 8's Avatar
I'll post the slip up when I get back in town on Saturday.
Anybody have an idea as to why boost won't raise up? I was using a Perrin boost controller controlling it through AEM, then we tried a Hallman manual with the same problem. The night before I was running 31 psi with no problem. Weird.
All the vacuum lines looked good. Can a Tial 44mm wastegate act up out of the blue like that? Spring stick?
Old Apr 30, 2007 | 05:24 PM
1killertsi's Avatar
sounds like something is up with the wastegate.
Old May 1, 2007 | 06:47 AM
2.3 Evo 8's Avatar
Yeah, when I get back in town I'm going to take it apart and check the spring.
I found one of my slips in my truck. The rest are in the glove box of the Evo. I don't think its my best run, but at least it will give you and idea.
60' ---1.622
330'---4.624
1/8----7.14
mph--96.69
1000'---9.33
1/4---11.173
mph--123.23
Old May 1, 2007 | 05:20 PM
rACerS's Avatar
Looks like some great driving. Are you still on regular radials? If so nice 60's
Old May 1, 2007 | 05:43 PM
2.3 Evo 8's Avatar
Thanks, I'm on BFG drag radials. I kept lowering my tire pressure and my 60' kept dropping.
I started at 24 psi and was cutting 1.66's and dropped the pressure to 20 psi and cut a couple 1.62's. I didn't know if 18 psi or lower would be ok so I just left it at 20 psi.
I was spinning all the way through 1st gear and half of 2nd gear. It was awesome!
Old May 1, 2007 | 06:48 PM
Dennis F's Avatar
I think a boost leak test is in order.
If you have a coupling thathas maybe just a hairline crak or rip that is opening up at 24psi that would cause a low boost condition as well.
Old May 1, 2007 | 06:53 PM
turbochrgdbeast's Avatar
wow...very nice. represent.
Old May 2, 2007 | 10:03 PM
evo3matt's Avatar
it was funny how everyone boost was acting up sunday.
Old May 3, 2007 | 04:53 PM
2.3 Evo 8's Avatar
Yeah, that was strange. You put up a pretty good time yourself Matt. That 60' is good for as slick as the track was.
