How did I do?
Old Apr 30, 2007 | 04:11 PM
BlackIX's Avatar
How did I do?
First time at the track with the Evo and AWD in general. I thought I would be able to get at least a 12.5 or better. Am I doing something wrong? I ran pretty consistent 110 mph traps. Shouldn't my car be trapping a little faster with the current mods? Still on the stock clutch and advans running 93oct. I know the reaction times suck but I was concentrating on launching for now. Let me know what you guys think, thanks! I'm number 407 by the way.
Old Apr 30, 2007 | 04:33 PM
Nvr2old32's Avatar
I'd say those are pretty good times & traps with your mods. Great job and pretty darn consistent. Get your 60' down to low 1.7s and you should get your 12.5!
Old Apr 30, 2007 | 05:49 PM
mdog's Avatar
Well, for your first time out with the Evo and AWD I would say that's not toooo bad. Your mph indicates you've got another .4 sitting on the table with better driving/shifting and a better 60'. As for reaction time.... who cares. It doesn't matter for your overall E.T. Unless you are bracket racing or something then it's a much bigger deal, as well as heads up racing, but in this instance it's not important. I noticed you have EvoScan, did you log any runs to check on knock counts etc....?
Old Apr 30, 2007 | 06:50 PM
kouzman's Avatar
Whats your 2-step set at?
At what rpm do you change gears?
I am just reffering to 2 of my mistakes, which actually were rookie-first-time-at-the-track mistakes... Maybe you did the same...
Usually the gearchange points are 7000-7200rpm and the 2-step needs to be at least 5800rpm... with that 2-step i just got away with bogging of the line and managed a 1.72 which is my best so far...
Old Apr 30, 2007 | 06:56 PM
BlackIX's Avatar
My wife had the laptop with her, so I didn't get to log any of these runs I have logged a lot of street pulls though and everything looks good, no more than 3 counts of knock randomly.
Old Apr 30, 2007 | 07:00 PM
BlackIX's Avatar
Had the 2-step @ 5600. I didn't bog at all really and it didn't feel like it was spinning either? Had the tires at 32 psi and I just let off the clutch till I felt the car start moving, then released it almost instantly (didn't dump it) I was wondering how to get a better '60 time. Snow tires maybe, lol. I see a lot of you guys say your ripping 1.6's with snow tires!
Old May 1, 2007 | 06:44 PM
Srt-4 Turbo 7's Avatar
I think thats damn good for your mods and first time with AWD. Congrats!!!
Not sure if your using a Jestr mail in flash or doing a custom tune. But as you already know a custom tune, 02 housing and LICP will get your car trapping a little higher. And with your driving will get you good et's.
Have you ever dynoed your car, if so what were the numbers?
Old May 2, 2007 | 06:55 AM
LayinLo's Avatar
Looks good and fairly consistent with what I've seen so far.
Old May 16, 2007 | 05:01 PM
Noize's Avatar
EvoM Administrator
You're holding 4th gear on the end, right?
Old May 16, 2007 | 05:02 PM
vortech_g35's Avatar
Not bad! Practice makes perfect.
Old May 16, 2007 | 05:16 PM
Evo9tunerz's Avatar
That's about what i ran with the same setup. Only difference was i had a worst 60 ft. being 1.9 and my 2-step was at 5k.
Old May 16, 2007 | 05:21 PM
EVORaab's Avatar
Very consistent times, and low too!!! Good job man
Old May 16, 2007 | 05:52 PM
Warrtalon's Avatar
Great job for your first time - no shame there.
As for faults and comments, here ya go:
- 60s aren't bad at all for a noob. You really only need to improve to low 1.7s instead of high 1.7s
- However, the shifting appears to be pretty slow. A high 1.7 or low 1.8 should show better ETs than this with 110+ traps
- Most IXs do make more power than that on those mods, but you just have an eflash, so it's not like you've been custom tuned in person
- Better/quicker shifting may result in higher traps, too
