Result after tune(1/8 mile)
Old May 19, 2007 | 11:33 AM
evovin's Avatar
Couple weeks ago i ran without tune(stock map) and walbro 255 fp(im also bogging down coz of my 2 step was 5k rpm)
8.4sec
2.0 60ft
@22psi
Last night i ran
8.6sec
1.80 60ft
79mph
@22psi
This is after tune and Walbro 255 fp(i didnt bog down this time coz my 2 step is 5400rpm)I was building 11psi at staging. also i got knock sum 34 when staging only!
I thought i should be running faster coz of my 60ft is faster and i have a tuned.
Should i put back my stock map???
Old May 19, 2007 | 11:52 AM
Warrtalon's Avatar
You should take the car to an expert and have them check it over from head to toe. The tune should have given you great gains, and with a much better 60', you should been running high 7s. Maybe the weather was worse, but to improve the 60' and lose .2s in the 1/8th is a bad sign.
Old May 19, 2007 | 12:37 PM
dsmfan95's Avatar
How long were you on the two step at the staging lights?
Old May 19, 2007 | 01:55 PM
evovin's Avatar
5sec
Old May 19, 2007 | 02:17 PM
Warrtalon's Avatar
It probably wasn't the problem, but you should try to limit the time on the 2-step. 5 seconds is a long time and not good for the car. At least you didn't say 15 seconds like some other crazy guy did once before...
Old May 19, 2007 | 03:27 PM
evovin's Avatar
i was stage already but the other guy was an idiot in the light! Is that why i was having knocks at staging?
Old May 19, 2007 | 03:29 PM
evovin's Avatar
also im running all season cheapy general tires 1.8 60ft.
Old May 19, 2007 | 03:46 PM
pac74's Avatar
try 7.3 with a 1.6 60ft, hehe
Old May 19, 2007 | 08:32 PM
Warrtalon's Avatar
All seasons are usually better than the Advans for launching, because they have softer sidewalls.
Old May 20, 2007 | 07:07 AM
evovin's Avatar
Would it make any better if i open my downpipe and get ss clutch line?
Old May 20, 2007 | 07:56 AM
Warrtalon's Avatar
Yes, but you are ignoring the problem and trying to mask it with more mods.
Old May 20, 2007 | 08:12 AM
Zoxygen's Avatar
Like warr said, there is serious loss of top end power what was the MPH difference between the two runs? with a .2 better 60' you should of gained quite a bit.
Things like boost leaks and clutch slipping (but you had a fine 60' so that might not be it) are common for problems like this.
Old May 20, 2007 | 08:51 PM
evovin's Avatar
hey Warr! did dynoflash tune your ecu or bushur?
Old May 21, 2007 | 06:25 AM
Warrtalon's Avatar
Al (Dynoflash) has done every flash on my car.
Old May 27, 2007 | 07:56 AM
S@nt0s's Avatar
im in the same boat as you my friend...
my VIII ran 8.4@81mph stock with just a cat back....tapering to 17psi as all stocks do
next time i went with o2 housing, TBE, HFC, K&N drop in, MBC@22psi ZERO TAPER!!! rc750's, 255 walbro.... and hell i threw in 100oct and bumped it up to 24psi and ran 8.6@80mph....
all things equal lauch , shifting EVERYTHING but the car wasnt going any faster...
i will be logging this week to see whats wrong with mine....
