MR owners, drag racing experience?
Old Jun 8, 2007 | 01:00 PM
UpstateEVOVIII's Avatar
Being a proud MR owner and suffering with the occasional trip to the drag strip, I wonder what other people are running with their MR's. Having to go into 5th gear is a real kick in the ***** when the 5 spd guys get to hang out in 4th to cross the lines. My current best is 12.2 @ 114mph with a 1.79 60 ft. Mods are TBE, Intake, MBC, FMIC, Meth, Flash. Running 27psi tapering down to 23ish. I'm guessing I'd be a good 4-5mph better if I had the 5 spd tranny, but enjoy the 6 spd and wanted the MR due to its suspension/features and not having to change a lot to get a lot out of it in return. Just wondering if any other MR owners had taken their car to the drag track. Hard to compare our numbers to 5 spd guys since they get to take the 4/5 shift off
Old Jun 8, 2007 | 01:06 PM
KawRider's Avatar
Im at 12.1 at 114 with a similar setup (06 MR). If we could get a better launch and shift a hair quicker we could see 11.9 or so. You should be able to stay in 4th gear (I do) and maybe that will help. The 5th shift may be hurting you a bit. Im no expert.
Old Jun 8, 2007 | 01:08 PM
bvdawg13's Avatar
i havnt gotton to run a 1/4 yet, but in the 8th mile i suffered from shifting into 4th right befor the line.....i havnt' gotton to do any runs with my new turbo set up
Old Jun 8, 2007 | 01:18 PM
What is your rev limit at that you can cross the line in 4th? I'm set around 7600rpm and if I try to cross in 4th its 110/111ish MPH. Tried it twice If I bump it to 8,000rpm and hold ever gear then MAYBE I could pull it off...but I can't imagine my stock head would love me for that.
Old Jun 8, 2007 | 01:22 PM
Warrtalon's Avatar
It seems you have deluded yourself into really thinking it's worse than it is. By no means would you suddenly pick up 4-5mph just by having a 5spd. If you're only trapping 114, then you're still not near the end of 4th gear. You shouldn't be shifting to 5th until you start getting up in the 117-118mph area - right now, you should have no problem staying in 4th. Also, if you're hitting 12.2s at 114, then it's not the trans holding you back. Before cams, alky, manifold, and o2, I hit 12.015 @ 111.7 and 12.000 @ 113.7. The 12.015 was with the stock rev limiter (7600) bouncing off it through the traps. The 113.7 was with a 7800rpm rev limiter, and I never hit it before or after the traps. If I was able to hit 114.xx, then it would have been an 11.9x. There are also plenty of other MRs with full bolt-ons + cams + alky who are trapping higher and going deeper into the 11s.
When I moved to high altitude, I had to start shifting to 5th even before the 1000' mark due to how drastically the powerband is shifted to the left due to altitude (on the stock turbo anyway). However, instead of hurting me, it actually helped me. If I held 4th to the end, I'd trap 106-107, but as soon as I started going to 5th, I trapped 109.5 consistently with 12.3-12.4s ETs. So, shifting to 5th in and of itself isn't that horrible, but it certainly is preferable if you can stay in 4th without sacrificing too much power. You're at sea level, so you can afford to stay in 4th until you're trapping much higher than 114.
Old Jun 8, 2007 | 01:24 PM
Warrtalon's Avatar
Well there's your problem. 7600 is the stock rev limiter. Why is your limiter still set to stock when you have all those mods? It should be at least 7800 and maybe 8000. It's common knowledge that we can rev to 8000 without upgrading head internals. I had no idea that all this time with your multiple threads complaining about the 6spd that you still had the stock rev limiter. Had I known, we could have remedied this a long time ago.
Old Jun 8, 2007 | 02:26 PM
Q@EvoPowerMods's Avatar
whatever one wants to say about Warr...he does know his stuff...+1
Old Jun 8, 2007 | 07:55 PM
ProccoEVO's Avatar
My friend Scott from TTP At Orlando Speed World on Friday the 8th 06, he broke the 10sec barrier on the stock turbo not once, but twice. he ran a 10.92@129.94, and backed it up with a 10.94@129.87, setting the new record for fastest 16g Evo MR he always have to go to 5th gear. check it out
click here
http://videos.streetfire.net/video/0...920129eb67.htm
http://videos.streetfire.net/video/d...92013b0b70.htm
or just visit his web @
http://www.ttp-engineering.com/
Old Jun 9, 2007 | 06:06 PM
Warrtalon's Avatar
Scott has been using a 5spd for a while, though, Procco. It's not an MR anymore (same with me).
Old Jun 9, 2007 | 06:16 PM
Raised my rev limiter to 8000 today. Looking forward to seeing what type of difference this makes. Will post results Wed. Thanks for the input. Good to see others results!
Old Jun 13, 2007 | 12:38 PM
Kee1pride's Avatar
lameo 12.3s at 110 for me.
wish my car pushed out the power you guys does. why am i getting such low traps for my et's?
stupid MR gearing
Old Jun 13, 2007 | 12:47 PM
TTP Engineering's Avatar
stupid MR gearing
Your poor attitude is probably what is holding you back.
My rev limiter was at 8500 for a long time.
The shifts to 5th gear would lock out on both stock clutch and ACT single disc XTSS. I have even lost a race at an NHRA event due to this lockout.
You should feel comfortable with an 8200rpm limit that will give you the ability to run into the 11 sec range.
Old Jun 13, 2007 | 01:08 PM
Kee1pride's Avatar
you'd have a poor attitude too if you saw everyone else running faster times with higher traps with worse 60 foots.
my friend richard rode with me a couple times and he ran 13.0 in his 06 sti. for an 06 sti, he definitely has the driver mod. he told me i shift every bit as fast as he does and my launch is only slightly slower. he cuts 1.68-1.70 pretty consistantly and im doing 1.73-1.75 consistantly.
im an 05mr with tbe/ catless, intake,fuel pump, exhaust mani, o2, forge bov and mbc, gsc 272/272s, act clutch and flywheel, tre transmission, ported head and an evo9 turbo, upper and lower ic pipes and a upgraded fmic.
only doing 12.3 @ 110
clay was doing 12.2 with clutch, exhaust, drop in filter, fuel pump, mbc and a tune.
Old Jun 13, 2007 | 01:11 PM
BURNALL_4's Avatar
oops...double post....see next one.
Old Jun 13, 2007 | 01:12 PM
BURNALL_4's Avatar
If i dont see an 11.9 out of that tonight im gonna be pissed......you've got way more stuff done and should kick my donkey.
