Im that bad of a driver????
Old Jul 16, 2007 | 06:34 AM
  #31
sharkm87's Avatar
Originally Posted by matt55
if he dont have any power at 7100 what makes you think he got more at 7500
the car is just sour
you see a dynograph?
Old Jul 16, 2007 | 06:37 AM
  #32
Warrtalon's Avatar
Power isn't randomly going to increase from 7100 to 7500 on a stock turbo'd car. This car is very weak and shifting at an rpm further out of the stock turbo's efficiency isn't going to change that.
Old Jul 16, 2007 | 06:43 AM
  #33
dcorn's Avatar
Wow, I have the same 60 ft times as you with close to 400rwhp and bald street tires. You should be ripping at least 1.8s or 1.7s.
Old Jul 16, 2007 | 06:44 AM
  #34
gerthiekins's Avatar
oh boy, do a tune that will help tons. with my mods i ran a 13 flat my first time at the track and my fastest 60' was like a 1.7x
Old Jul 16, 2007 | 07:23 AM
  #35
Warrtalon's Avatar
The Xede is his tune.
Old Jul 16, 2007 | 07:33 AM
  #36
mac_05evo's Avatar
Originally Posted by svtkiller
Please explain to me HOW your xede works as your boost controller!!!!!
the Xede does control the boost via the stock boost solenoid.. Just go to the boost map and raise/lower the values in the certain RPM/Load point to whatever you desire
To the OP, I'd ditch the Xede and just go with a flash. One of the main reasons, there are a LOT of people who can tune via ECUflash but only a few who actually mess with the Xede now days. Also, the stock ECU can do pretty much everything the Xede can so it's kind of pointless now.
Old Jul 16, 2007 | 04:18 PM
  #37
frost318's Avatar
I might just end up pulling the xede off when i get up there for my tune. I will just have him flash the ecu. Thanks for everything
Old Jul 16, 2007 | 07:52 PM
  #38
SteelEvo's Avatar
that sux i have no cams...tbe fuel pump boost controller...in 82 degree 65% humidity did a 13.2@106 with a 1.9xx 60ft
Old Jul 16, 2007 | 07:58 PM
  #39
34Turbo's Avatar
Originally Posted by aramsey80
I think you just might have a mood disorder. You say such nice things in your posts.
  #40
midwestmonster's Avatar
Getting locked out at the higher rpms is not helping either. Another case of the famous ACT lockout at high rpms.....
Old Jul 16, 2007 | 08:26 PM
  #41
Jasil's Avatar
Famous ACT lockout is driver and adjustment dependant. TT ran 9's on a ACT single disk and TTP ran 10's on a ACT single disk. It's all about adjustment and the minute you ride it too much and warp the disk ever so slightly it's all over.
I'm not a big single disk advocate but many people have run good time with no problems. Slipping a single disk is bad news.
Old Jul 16, 2007 | 11:33 PM
  #42
TTP Engineering's Avatar
We have a new version ACT with TTP spec custom disc that holds more power than HDSS and XTSS without any of the lockout issues at high rpms. PM for more info.
To the OP. Ditch the XEDE and get a manual boost controller and eflash at the least from a qualified EVOM vendor. We just so happen to be one of those vendors. Let us know if you are interested and have access to a reflash cable.
Old Jul 19, 2007 | 03:36 PM
  #43
svtkiller's Avatar
So how do you run two maps via a flash?
Old Jul 19, 2007 | 04:06 PM
  #44
mcwop23's Avatar
laptop
Old Jul 19, 2007 | 07:39 PM
  #45
Warrtalon's Avatar
Caveman alert!
