Im that bad of a driver????
Old Jul 15, 2007 | 01:22 PM
frost318's Avatar
I went to no problem race way In donaldsonville. I just had my cams installed about a month ago. so i figured i would go give the track a shot. This was my first time at a track running my car. I did not get a chance to do a boost leak check. But i was hitting 21psi. The car felt normal nothing different than normal. Just wondering if im that bad of a driver or is it other problems. I am going to run a boost check this weekend when i have some free time. I was thinking it was b/c i am not tuned. So i am getting tuned on the 28th of this month. My friend said i might be that bad of a driver. But also as i made two more passes the time got worse and my trap speed was way down from other cars with my mods. Just would like your thoughts. Thanks
R/T....... .879
60........ 2.064
330...... 5.699
1/8....... 8.730
MPH...... 82.49
1000..... 11.352
1/4........ 13.570
MPH....... 103.56
Old Jul 15, 2007 | 01:26 PM
evoracingstar's Avatar
ur running with out a tune with those mods?? thats most likely the problem!
Old Jul 15, 2007 | 02:33 PM
Nvr2old32's Avatar
Get tuned! That's your problem. Seems like your shifting is pretty slow too especially from 1st to 2nd. Also, get your 60' down. 2.0 is no good. With a tune and some practice, you should start seeing some better times/traps.
Old Jul 15, 2007 | 02:36 PM
frost318's Avatar
Yea i know my 1st to 2nd is slow. I keep getting locked out of it for some reason. But there is no grinding so its not the syncros.
Old Jul 15, 2007 | 02:37 PM
sikrsix's Avatar
those 60fts are from a fwd geo metro!! Not an evo!! Should be at worse a 1.8xx
Old Jul 15, 2007 | 02:38 PM
JJAXON84's Avatar
just need to work on your sixty foot times and get a tune. What are you launching at?
frost318's Avatar
Im launching at 5000
Old Jul 15, 2007 | 02:43 PM
WongFu's Avatar
To be honest if this was your first time at the track its not that bad at all. But there is much room for improvement.
Old Jul 15, 2007 | 02:50 PM
Lancematic's Avatar
You need a tune, period.
Old Jul 15, 2007 | 02:51 PM
Warrtalon's Avatar
yes, your driving is that bad, but the car is very slow, too. If you have those mods without a tune, then that is completely asinine and pointless. If that K&N in your sig is the Typhoon, then your car is just a mess, but if it's a drop-in filter, then that's fine (list it that way, though).
What is Exede? Is that Xede or Exedy? I don't think it's a Xede, becase you're not tuned, and I don't think it's Exedy, because you have an ACT 6-puck. So, what is an "Exede"?
Your power is equivalent to a stock 05 btw.
Old Jul 15, 2007 | 02:56 PM
frost318's Avatar
The K&N is a drop in filter. And i do have xede. Sorry about the sig. fixed
Old Jul 15, 2007 | 03:12 PM
jrsimon27's Avatar
if yopu have an xede then you have a tune...
launch higher
Old Jul 15, 2007 | 03:15 PM
frost318's Avatar
I can not launch no higher than 5000. I am tuned by the xede but i was talking about as for as going to a tuning day and let someone tune it. Sorry for the confusion.
Old Jul 15, 2007 | 03:57 PM
Warrtalon's Avatar
Huh, if you're tuned, then you're tuned. It's not only a tune if you "go to a tuning day."
That's one horribly weak Evo if it's tuned with cams...
Old Jul 15, 2007 | 03:59 PM
mcwop23's Avatar
try to sell the xede, it's pointless
