Ok, let's the beating begin!!
Old Aug 3, 2007 | 08:30 AM
Forrest Gump 9's Avatar
Originally Posted by SOEuro
what did u do when u launched?????
Well, I staged the line, pulled on my e-brake, staged the second set of yellow, dropped the e-brake, clutch in, half way in on the gas, and tried to slipped the clutch. May be next time I need to floor the gas and build some boost and work a little bit more on the clutch.
Old Aug 3, 2007 | 09:24 AM
05WhiteEVO8's Avatar
Don't Ebrake at all, hold your gas pedal to the floor, literally floor it ( I had the same issue when I first got the EVO I didn't completely floor it off the limiter), so I unhooked it and BAM 1.6 60's. But you need to slip the clutch out and keep the gas pedal down. You will know when you do it right by hearing a little tire squeal (and I mean a little).
Old Aug 4, 2007 | 07:02 AM
The reason I used the e-brake is to load the drive train, so no shock to them.
Old Aug 6, 2007 | 01:25 PM
BURNALL_4's Avatar
Originally Posted by EvoVIIIJeremy
lots of practice equals new clutch
hahaha.....Welcome to my World!
Old Aug 6, 2007 | 03:28 PM
SinisterAgent's Avatar
Originally Posted by AlohaEvo
RT has nothing to do with 60's...you can sit at the tree for 3 seconds and still pull a good launch at 1.6
+1 Very True! And you had the e-brake on.. JK. But honestly if you want a good launch just bang that ***** of the revlimit <--- (Its there for a reason ) and feather that baby until you smell a bit of clutch and hear your tires chirp ever so slightly. Youll get it, eventually.
Old Aug 8, 2007 | 06:49 AM
I see that you drive a STI, that car is a lot easier to launch than the Evo. The Sti doesn't have the rev-limiter/launch control, the Evo had one from the factory. I drove my cousin 07 STI and consistently get 1.6s 60' time. On the STI, all I have to do is rev that thing up to 6K and dump the clutch.
As the Evo go, I think I got the hold of it. May be this Sunday I'll get some free time and head back to the track. Hopefully a better 60' time and a better time slip over all. Thanks for the tips guys.
Old Aug 8, 2007 | 08:37 AM
mcwop23's Avatar
you should have your two-step set to 6K anyway since you're tuned. With that the evo is the easiest car to launch in the universe.
