1st time at the track - What should I expect?
Old Aug 10, 2007 | 08:45 AM
BOOSTEZ's Avatar
Hello guys!
I'm finally going to put my EVO through some abuse and see what it can do at the track tommorrow..
I'm a little worried about what it SHOULD do down the track with my whp and my lack of track experience. So, my question is: What should a ~300whp EVO do with a non-experienced track driver? What are some of the times of other evos that have this setup?
Thanks,
-M
Old Aug 10, 2007 | 08:50 AM
steevo's Avatar
High 12's.
Old Aug 10, 2007 | 08:52 AM
EVOL2003's Avatar
start saving for a clutch....
you should be trying to figure out how to launch
Old Aug 10, 2007 | 08:56 AM
Duby's Avatar
12.8-13.2ish would be my guess, only from seeing other evos do that. If you've never launched before, plan on a 1.9-2.1 60' and 99-104mph trap speed
mods ?? maybe boost controller, cone filter and exhaust for 292whp is that a mustang dyno or dyno jet . . . to be honest there are too many variables but like I said previously, those times would be typical for a first time at the track with roughly that power
Old Aug 10, 2007 | 09:04 AM
Mr. Evo IX's Avatar
probably low to mid 13's with inexperienced driver.
Old Aug 10, 2007 | 09:20 AM
psphinx81's Avatar
ill be going for the first time on the 26th.. mods in sig. yes i have a upgraded clutch lol
Old Aug 10, 2007 | 09:25 AM
BOOSTEZ's Avatar
I should have stated. I have an ACT clutch with lightened flywheel and a 2-step rev limiter at 6,000.
Mods:
3" full exhaust (no cat)
tubular headers
boost controller
k&n drop in
-M
prj.evo's Avatar
I would say if you can at least get a 1.8 60' you should be in the 12's.
Old Aug 10, 2007 | 09:27 AM
BOOSTEZ's Avatar
I've launched several times before on the street. I don't think that's going to slow me down... I also have a 2-step rev limiter.
-M
Old Aug 10, 2007 | 09:28 AM
BOOSTEZ's Avatar
Would 60' be around my entire 1st gear (0-30mph)? Just trying to gauge when I would be pass the 60' according to my instrumentation.
-M
Old Aug 10, 2007 | 11:24 AM
Duby's Avatar
you should be running 11.9-12.2 with good driving
Old Aug 10, 2007 | 01:25 PM
upstatescevo's Avatar
with a tune on a stock clutch with your setup i ran a 12.6
Old Aug 10, 2007 | 02:27 PM
Warrtalon's Avatar
Errrr, no. Where did you get those numbers? Look what you run with 70 more whp. With 292whp on a Dynojet, he'll trap 107-108 and run high 12s with 1.8-1.9 60's.
OP, 292 is not 300. I know it's close, but each 10whp is about .1s and 1mph. With 305whp on a Dynojet, I ran 12.26 @ 110 as you can see in my sig, but I wouldn't expec that if you're inexperienced.
Also, thinking that launching won't be a problem just because a) you've tried it on the street and b) have a 6k limiter is foolish thinking. The 6k limiter doesn't make suddenly able to launch, and the street is nothing like the track. You'll find out.
Old Aug 10, 2007 | 02:32 PM
06EVOIX SE's Avatar
i did a 12.9 my first time in the car, so you should do better then that.
Old Aug 10, 2007 | 02:33 PM
SPEED's Avatar
Get the launch down, and you'll be alright. Good luck!
