what tires running to run 11"s with stock turbo
Old Sep 9, 2007 | 11:08 AM
mandy1's Avatar
what tires,air pressure and 60ft you guys running with stock turbo to obtain 11"s passes?
Old Sep 9, 2007 | 12:51 PM
willum14pb's Avatar
dunlop winter tires, 26 psi all around, 1.64 60' on pump was my best...
Old Sep 9, 2007 | 02:52 PM
Luis@TTP's Avatar
yokohama es 100 34psi 11.9. 60fts range from 1.72 to 1.9s
Old Sep 9, 2007 | 06:54 PM
1slowevo's Avatar
dunlop all seasons 26-28psi, lowest 60ft was 1.60, but usually 1.7-1.75
11.8 @114 was the best ET
Old Sep 9, 2007 | 07:02 PM
Luis@TTP's Avatar
did you run 11.8 at 114 with the setup in your signature
Old Sep 9, 2007 | 07:03 PM
fastrob691's Avatar
Michelin PS2, 32 front 29 rear, 1.72 best 60, still trying to figure out the magic launch and get into the 1.6 range, I just spin, either spin and move forward or like I am in water which results in 1.9 60's. Good luck, got RT-615's now but lights at the track were messed up last time so no documented times with the Falkens yet, but they hook great on the street.
Old Sep 9, 2007 | 07:16 PM
NIevo's Avatar
Hankook Ventus HRII's. Pressure at 22psi and launch at 6k. Best 60' was 1.58, average is 1.63-1.67.
Old Sep 9, 2007 | 07:33 PM
kouzman's Avatar
on the stock tires i ve managed low 1.70s 60ft with 1.70 the best of all... Thats with 40psi tire pressure and the stock clutch tranny...
now i changed to 18s Falken 615s, sheph tranny and ACT clutch kit... havent tried this setup yet...
Old Sep 9, 2007 | 07:35 PM
Warrtalon's Avatar
You can do it with any tires.
Old Sep 9, 2007 | 07:42 PM
wizzo 8's Avatar
Does tire psi make a diiference in our cars? If so what should my psi be if My front tires slip? I know if you have a rwd car with slicks you want to run a lower psi but with awd Im not sure
Old Sep 9, 2007 | 08:27 PM
mandy1's Avatar
ok,i was wondering that all that 1.6-1.7 60ft was with drag radial.now i see it wasnt.so lower the front tire pressure and a good launch at 6k with 2 step will do the trick,thanks boys.
Old Sep 9, 2007 | 08:41 PM
evovin's Avatar
Its true!!!!1.74 60' I got this set mounted when i bought my preowned evo. they run 78 bucks/tire http://www.tirerack.com/tires/Compar...=All&x=76&y=15
Old Sep 9, 2007 | 08:49 PM
jamerin's Avatar
^^^ i second that!!!!
Old Sep 9, 2007 | 08:53 PM
4WS Tuning's Avatar
kumho mx 255/45/17
18 front/22 back
low 1.6's one 1.5
Cheers!
Old Sep 9, 2007 | 08:57 PM
4WS Tuning's Avatar
it depends on the tire.... i have a taller tire, so the sideways are softer, so when i drop the tire pressure the tires squat alot more than the stock height sidewall... so that means im benefiting more.
This was the closet thing i can think of besides a drag radial since i cant daily that in Fl with all the rain, thats an accident waiting to happen. Worked out like i had hoped, i got them mainly to be able to launch hard on the street, on the track you can make anything hook.
Cheers!
