Wheel Hop + high traction results...
Old Oct 7, 2007 | 06:36 PM
kouzman's Avatar
Air Temp: mid 70s
Tire Pressure: 34psi warm
2-step: 6250rpm
fuel: C16
weight: 3500 pounds with driver ( i know i am too heavy)...
First shakedown pass at 25psi a 12.200 @ 114
I got insane wheel hop on this pass and i babied all gearchanges... my gearchanges from 1st to 2nd, 2nd to 3rd and 3rd to fourth were taking 0.47-0.48 sec (100 tps - off the gas - shift - 100 tps again)... Boost was spiking at 25psi...
Second pass i wanted to try more boost so i turned my boost controller 2.5 turns more... I stage the car, go on the 2-step, launch...
The car span all four, went sideways and SNAP.... coasted the track and stopped moving on the return road...
Results...
The car was fixed the next day and for that i want to THANK Manny from Top Level Performance who drove all the way to New Jersey to tow the car and of course MASTER JIMMY @ THE SHOP, CT and Marlin who fixed the car in a few hours...
I guess i have to invest on some suspension mods to cure the wheel hop problem...
Old Oct 7, 2007 | 06:56 PM
Warrtalon's Avatar
No, you don't need suspension mods to stop wheel hop. Just have to figure out the right combo of tire pressure and launch method.
Old Oct 7, 2007 | 07:05 PM
kouzman's Avatar
I 've read all the threads in evom on the subject...
i agree with you Warr... however i have to say that i am still on the stock mounts, no torgue damper no nothing... i have a quite aggresive clutch, a built tranny so it makes sense that when something goes wrong, the weakest part will break...
Usually i use 40psi tire pressure to spin instead of breaking something.... This time though i went lower... and obviously i twas a mistake... Ohhh well... we learn from our mistakes...
I will do some upgrades howeveer... probaly i will invest on better engine mounts and rear trail arm bushings and maybe the moustache bar from AMS... i just cant stand the loud thumb from the rear diff when i am aggresive on the gearchanges...
kouzman
10
Feb 5, 2010 12:09 PM
kouzman
Jan 31, 2010 05:46 AM
kouzman
38
Mar 6, 2008 07:34 PM
kouzman
Jun 26, 2007 11:57 AM
kouzman
Nov 13, 2006 09:22 AM
