New personal Best today!
Subscribe
Oct 28, 2007 | 04:18 PM
Nice
Reply 0
Oct 28, 2007 | 04:19 PM
There are 2 Stage 2 and 3 Evo 9's here that arent running or trapping that high. So by process stage 3 on this car is goina run low 11's????????? Something doesnt seem right?
Reply 0
Oct 28, 2007 | 04:23 PM
Not all cars are the same and stages don't really mean much. It's what the total package does for a particular car, the weather conditions of the run (probably had optimum conditions today), the driving, the track conditions, and astral alignment.
Nuked, surprising it only hit 114 holding 4th with 91+ in the 1/4, but I guess the gearing was giving out on you...
Reply 0
Oct 28, 2007 | 04:24 PM
a good tune should get you 11s on stage 1, my problem is for some reason i can't 60' any better than 1.78 these days and when i do get a couple low 1.7xs i miss a gear. I have gotten 1.65s several times in the past so I don't know what the problem is. Yesterday in gainesville I ran a 12.02, 12.04, 12.05, and 12.07 all at 114.5-115.25MPH. If i had an actual race gas tune I'd probably trap about 117-118 on this setup but as it is i spike 25psi on 100-octane running my 93 tune.
Reply 0
Oct 28, 2007 | 04:34 PM
Quote: Not all cars are the same and stages don't really mean much. It's what the total package does for a particular car, the weather conditions of the run (probably had optimum conditions today), the driving, the track conditions, and astral alignment.
Yeah I start dropping hp at 6800rpm and I held it out to 7700. Plus I run alot of boost compared to most, I am pretty confident the stock fmic is pretty maxed with this turbo by 4th. I never pickup as much mph on the back half as most stock turbo evos seem too.
Something else. My clutch is still crappy. First run I used the 2step as normal and just roasted it again. Second run I figured I would try driving it like a FWD/RWD and feather the gas around 6k, worked like a charm.
But yes conditions were great, track prep was pretty good too.
Reply 0
Oct 28, 2007 | 04:47 PM
Here is the vid...
Reply 0
Oct 28, 2007 | 05:21 PM
Congrats again, Jason! That car exploded ahead when you nailed second gear.. I'll always remember that run for that one shift, hehe.
<---- camera man that doesn't zoom enough
Reply 0
Oct 30, 2007 | 08:33 AM
great job man.. 26psi is a bit though on pump gas isnt it, do you daily drive this car?
Reply 0
Oct 30, 2007 | 08:53 AM
Very impressive and great driving!
Reply 0
Oct 30, 2007 | 12:16 PM
Quote: great job man.. 26psi is a bit though on pump gas isnt it, do you daily drive this car?
Yes daily driver (not that I drive far). 26psi is what I have been running for some time now on pump.
SQ
Reply 0
Oct 30, 2007 | 12:40 PM
26 psi seems slightly high, but Great times none the less. You need to change your avatar now
Reply 0
Oct 30, 2007 | 12:52 PM
So is that track down hill or is the shut off area up hill? Looks funny in the vid, great job for pump gas.
Reply 0
Oct 30, 2007 | 05:20 PM
Man, great job. excellent driving. Have you dynoed your car yet?
Reply 0
Oct 30, 2007 | 06:16 PM
Shutdown goes up hill. Track is pretty average as times go. Prep usually is not all that great. I will be heading to Mason Dixon which has better prep and lower elev. soon. Gonna throw some race gas in and see what she will do. Hoping for 11.6's
Car did 354tq/336hp on the Atlantic Motorsports Dynomite Dyno.
26psi may seem high, but for some reason my car will take it. No knock, and the timing is not low as most would think. For referance, a local friend has a 9, same mods as me. When we tuned it on lower boost (23psi) it would not take the timing that mine did without knocking. Same fuel everything. Some cars are just stronger then others I suppose. Now I am trying to decide between going stg4 and stopping or going to a 3065....
SQ
Reply 0
Nov 1, 2007 | 07:12 AM
Time to change that avatar, Nuked.
Reply 0
