Locking all 4 brakes to launch??
Paul (Ifarted) with the 1000 WHP beast said the following in a post today and I am trying to understand this.
Anyone understand this?
One thing i wish i would have done was put a hand brake in that locks all 4 brakes up off the line but didn't do cause of our crazy race schedule. After talking to Shep at SEMA its a must if im going to get a good 60ft
https://www.evolutionm.net/forums/sh...ht=dan+bajalis
yes I have this currently installed on my car. The last event I had a hard time staging the car since I don't have an e-brake anymore. So this allows you to roll up to the line, pre-load the clutch, and release the lever off the launch... should work out nice, can't wait to try it out
By pulling up on the e brake or using line locks allows you to pre- load the drive train, take the slack out of it, and load the rear suspension. Which leads to quicker launches and less broken parts.
you can do it several different ways, mechanically have a lever attached to your existing brake pedal, or hydraulic, T into your brake line and use the lever to activate/de-activate the brakes (front, rear, or both)
Lets say that it is set up like a line lock and you pump the pressure up and lock all 4 brakes. Is that enough to really hold the car back from say 25 psi of boost and 7,000 rpm? If this is the way you are doing it and it works I am sold. It must be much easier on the driveline when you leave. So you simply release the button to launch?
well Line lock is more like a solenoid and you use a button to release the brakes. The one I'm using is a hydraulic lever, and its not like an on off switch this meathod will be a lot smoother and easier to stage with in my opinion. I personally would not launch at 25psi at 7k, that's just asking for trouble, I launch with about 5-10lbs of boost and have a smooth launch.
You find the spot in the clutch disengagement where the clutch is starting to engage, -- it's not "full out" but it's loading the drivetrain, taking up the slack. The brakes hold the car back against some of the clutch engagement. You then release the brakes while going to full engagement on the clutch. You can also build some additional boost because of the loading of the engine.
