First time out on my BR3065
Old May 14, 2008 | 08:14 PM
kouzman's Avatar
Info about the conditions:
Pump gas, the car wouldn't pass 22psi ( i am changing to ebc this saturday bc mbc is not that consistent), ran on my winter tires, and the car was weighting with me in 3404 pounds... Always full lift shifts...
1. First run i didnt launch the car. Of course i bogged of the line, saw what lag means and then went... Here i saw that i only had 20-21 psi of boost and the car was knocking in 4th slightly...
rt 1.081
60ft 2.181
330ft 5.716
1/8 8.471
mph 89.85
1000ft 10.812
1/4 12.761
mph 114.68
No video
2. Second run i decided to raise the boost on my mbc targeting my 23psi tuned, however again i didn't see more than 22psi... Launched at 6100rpm... The car span but again i was knocking in 4th... Another mistake i was changing gears way to soon for my powerband since now i keep making power all the way up to 7800rpm...
http://www.youtube.com/watch?v=QiDjNVFzW0M
rt 0.937
60ft 1.85
330ft 5.163
1/8 7.867
mph 91.05
1000ft 10.204
1/4 12.14
mph 114.81
3. I tried to figure out why the car was knocking in 4th gear only and actually was feeling very "tight" like holding back... Lowered the 2-step to 5900rpm to lessen wheel spin but actually i spinned even more... i also tried to keep my gearchanges more but i kept hitting the rev limiter...
http://www.youtube.com/watch?v=AqVh4...eature=related
rt 0.859
60ft 1.859
330ft 5.13
1/8 7.833
mph 90.76
1000ft 10.17
1/4 12.102
mph 115.05
4. Last run of the day. Lowered my rev limiter even more to 5700rpm but actually i spinned even more this time, bouncing the rev limiter for quite some time... Still so and so launch with a bad 1.85 60ft and maybe knocking in 4th again... My battery went on my laptop so i couldn't even see what was wrong...
http://www.youtube.com/watch?v=ClcCO...eature=related
rt 0.918
60ft 1.849
330ft 5.102
1/8 7.786
mph 90.03
1000ft 10.091
1/4 12.007
mph 116.00
I have to say that the car definitely feels faster than before but i had to solve these issues i had. Two things probably happened... The car had less load than tuned at the track thus reading lower load cells with too much timing and/or the Exxon gas that i had in the car was ****ty...
I expect much higher traps on pump when i resolve these small issues plus i definitely need other track tires than my SP Winters... Just from the 60ft if i had my usual low 1.70s the car would be in the 11s easily...
More to come when i find time for the track again...
Old May 14, 2008 | 08:18 PM
quick silver 8's Avatar
nice runs
Old May 14, 2008 | 08:28 PM
k2boarder3187's Avatar
get those bugs worked out! your stock turbo times vs the 3065 are too close right now! lol what track is that?
Old May 14, 2008 | 08:29 PM
06evors's Avatar
Definately nice runs and GL finding the bugs. With sticky tires you won't even have to try for 11s.
Old May 14, 2008 | 08:31 PM
broddey's Avatar
I think your traction issues stem more from overheating the tires. What was the delay between runs? Do you perform a burn out?
Play with the tire pressures a little. You will be suprised at how much a difference it makes.
Old May 14, 2008 | 08:39 PM
kouzman's Avatar
Its Etown...
Actually where was plenty of time between runs but i guess the track temp was raising throughout the day...
No i dont do a burnout... maybe i should have done one but at that point i was trying to figure out the 4th gear knock... from my frustration i didnt even lowered my tire pressure... lol....
Sticky tires will be ordered soon plus i have another 60-70 pounds to remove from the car without even trying. Still have full interior, both crash beams, trank cage, etc...
i am sure that next time will be better... I only have 23 drag passes since i bought the car so i am still a rookie....
Old May 14, 2008 | 08:48 PM
JuniorAWD's Avatar
Kouz, we will fix her up... Should be @ the 120mph range on pumpgas.. Once all the issues get ironed out she will fly
Old May 14, 2008 | 09:10 PM
kouzman's Avatar
yep.
I now we will. I am not worried at all. Just need to find the time during the weekends. Lately my working hours are pretty insane.... Even in the weekends...
Old May 14, 2008 | 09:12 PM
Ultimate CC's Avatar
Not bad for the first time out...keep at it...
Old May 15, 2008 | 06:48 AM
JuniorAWD's Avatar
Originally Posted by kouzman
yep.
Send Jamie Kennedy with the car, all we need to do is log a few times and see were the issue is coming from.
Junior
Old May 15, 2008 | 10:32 AM
EatSleepBoost's Avatar
yea once you settle out ur knocking and get a tight tune ur traps will improve cause those are low traps
Old May 15, 2008 | 10:39 AM
Gavin@TopLevelPerformance's Avatar
Hey kouzman come down sunday,Im looking to go better then my 11.8 pass at e-town dont worry junior got your back..
Old May 15, 2008 | 10:52 AM
StreetThisEvo's Avatar
Keep up the good work! It just gets better from here.
Old May 15, 2008 | 01:11 PM
hey manny what track you goin to Island? im thinking about going Sunday weather permitting
Old May 15, 2008 | 07:05 PM
kouzman's Avatar
i wish i could but this weekend as well as the next one i have other things to attend and do than my car... unfortunately...
