Where can i purchase a staging brake/lever???
I am under the impression that a straight linelock requires to pump the brake 3 times to hold line pressure and then released.
That might be tough if he's sitting on the anti-lag w/ the right foot and the left on the clutch.
Am I correct that if I would use a dual cylinder setup like Paul and run each line to the rear caliphers through one of the cylinders, plus installing a switch for the ABS.
That way when I wouldn't be at the track I would have ABS and also the resiliency of the stock brake line setup ?
Megadeth2118
Lancer Aftermarket Forced Induction Tech
Aug 12, 2004 11:26 AM
