300whp and still slow
Old Aug 25, 2003 | 03:36 PM
  #46
SilverEvo8owner's Avatar
Okay, I really dont know, but was your A/C on
Also, how many miles are on your car??
Old Aug 25, 2003 | 10:36 PM
  #47
Rollaway's Avatar
my 1/8 was 82mph i think.. i'll post up the time sheet sumtime this week
Old Aug 25, 2003 | 10:37 PM
  #48
Rollaway's Avatar
got 2059 miles on my car and my car weighs 3372 with 1/4 tank of gas
Old Aug 26, 2003 | 12:16 AM
  #49
Myxalplyx's Avatar
Welp
Well, just based on this info along with the rest you provided, I can say that you were headed for either a high 12.9? or low 13.0? run. Since your 60ft time, 1/8th mph, and 1/4 mph seem spot on and your time a bit slow...it would point to how you are shifting. Not saying you are shifting 'slow' but just that your aren't shifting fast enough.
Old Aug 26, 2003 | 12:27 AM
  #50
blurr's Avatar
That is really heavy, is that with you in the car? If now, where is all the extra weight comming from?
Old Sep 1, 2003 | 09:20 PM
  #51
RENN-ART's Avatar
can someone analyze my crappy track day that i did about a month ago..
i just need to know if i'm not shifting fast enough... i have a feeling i might be a bit conservative..
i ran only 3 times because my S-AFC2 settings were erased for some weird reason (i've heard it's happening to others), so i just did it for practice.. i knew they wouldn't be very good since i only ran the safe settings and only 19.5 psi..
1st run:
1.774 - 60ft
5.401 - 330
8.398 - 1/8
80.86 - mph
11.009 - 1000
13.20 - 1/4
103.11 - mph
2nd run:
1.839 - 60ft
5.483 - 330
8.505 - 1/8
80.34 - mph
11.126 - 1000
13.33 - 1/4
102.59 - mph
3rd run (increased boost to 22psi.. figured it'd be ok since i ran 100oct gas):
2.027 - 60ft (ARGH!! BOG!!)
5.715 - 330
8.709 - 1/8
79.81 - mph
11.30 - 1000
13.46 - 1/4
104.69 - mph (obviously the boost was set too low before!)
THEN THEY CLOSED THE TRACK!!! I wanted one more run so bad!
Should I even go back to the track and beat on the car again (my daily driver) with the more aggressive SAFC settings that I now have programmed again + the obviously more efficient 22psi and see if that's all it is, or should I wait til I get some more mods put on?
I should be able to run a 12.8-12.9 @ 106-107 with my current mods, right?
Old Sep 2, 2003 | 04:05 AM
  #52
Shadohh's Avatar
search and you will see my dyno graph
Rather rude of you.
The man is going out of his way to try and help your problem, and you want to make him spend more time searching for your dyno?
You should be curtesy and provide a link to it.
Time slip would help to so we can see your reaction times and trap speeds.
Old Sep 2, 2003 | 04:59 AM
  #53
Stinkapuss's Avatar
1st run:
1.774 - 60ft
5.401 - 330
8.398 - 1/8
80.86 - mph
11.009 - 1000
13.20 - 1/4
103.11 - mph
2nd run:
1.839 - 60ft
5.483 - 330
8.505 - 1/8
80.34 - mph
11.126 - 1000
13.33 - 1/4
102.59 - mph
5.715 - 330
8.709 - 1/8
79.81 - mph
11.30 - 1000
13.46 - 1/4
Looks like your shifting at redline. Try shifting at 7400ish in 3rd and see what happens.
Old Sep 2, 2003 | 08:04 AM
  #54
RENN-ART's Avatar
i do shift at redline..
i didnt think there was much more power up there with the stock cams.. but maybe that's my problem..
thanks!
Old Sep 2, 2003 | 05:31 PM
  #55
Noize's Avatar
EvoM Administrator
Originally posted by Shadohh
Rather rude of you.
He sure as crap isn't worried about being rude- Look at his not_work_safe avatar.
IMO, those 60' times prove that the problem isn't driver or clutch. It doesn't take that much finesse to upshift very quick, I'm sure you're doing that fine. The car dynoed well, so it certainly isn't a "weak Evo". Maybe if it dynoed like 220 with all those mods, I'd believe it was weak.
To me, the problem obviously has to be one of two things:
(1) The intake is freaking the MAF out (also the high intake temperatures) and although it was tuned fine for a stationary run on a dyno, high velocity of airflow is screwing everything up.
and/or
(2) The AFC settings. Personally, I don't think an SAFC is a very elegant solution for fuel management, particularly on this ECU. I have a $50 spot that says with the stock airbox and retuned to better fuel management, the car will make repeatable results to the dyno on the road and break into the 12s with ease.
The easiest/most obvious place to start is pulling that intake for a run at the track- if your AFC settings won't make the car pig rich with the swap.
Old Sep 2, 2003 | 05:35 PM
  #56
Noize's Avatar
EvoM Administrator
Thinking about this more, I feel it is definitely the intake. Hot under hood heat, no protection for the element from all the heat, and the car is injesting idiot hot temperatures and running like crap.
Easiest thing to test in the world!
Old Sep 8, 2003 | 07:34 PM
  #57
4LBEAT8's Avatar
Could it have been an over-zealous dyno? I've seen a HUGE variance in numbers for the same parts.
Old Sep 8, 2003 | 07:36 PM
  #58
Rollaway's Avatar
oh damn.. sorry for not replying in a while.. i had the nothing is wrong with my car anymore and forgot to go back to my post syndrome... going to track maybe this week and keep u guys updated
Old Sep 17, 2003 | 11:19 PM
  #59
Rollaway's Avatar
heres an update for all you people... sorry i took soooooo looong... but it was all worth it... sorry for the not so work safe avatar.. that is now changed... and i wasnt being rude when i said search it...
well heres my new topic updated
https://www.evolutionm.net/forums/sh...threadid=39983
dsm nexus
Feb 22, 2017 02:32 PM
FreakEVO
Aug 5, 2016 10:21 AM
dsm nexus
Aug 24, 2015 08:10 AM
SeanC
50
Mar 21, 2009 04:09 PM
hova00
123
Feb 17, 2009 10:56 AM
