More 1/8th Mile Improvements :D
Nitto 555R DR's with Enkei RPF1 17x8.5 wheels. I've yet to let much air out... I've been as low as 25psi in them so far... I may go back Friday if the weather holds out.
Nice times! I run around the same 1/8th as you and turn 11.1's right now. Nice driving for sure and get to a 1/4 mile track and lets see some numbers
You are very close to 10's. Are you running AEM?
AMS sells a Wilwood brake kit which allows you to run as small as a 15" wheel.
Unless it's a track only drag car I personally wouldn't do it. his 1.5x-1.6x 60'ft times are good enough to net him a good 1/4 times.
It's pretty much a drag car but still fine on the street. It has no A/C or heat and all the sound deadening has been removed. I've removed a lot of little things but it still has door panels, dash, carpet, etc... I remove the seats and anything that comes out easy at the track... with 1/2 tank maybe a little more of gas it weighed 2830 w/o me in it.
This track is somewhat slick... at a fully prepped track i would expect low 1.5x's all night long. I just can't justify spending all the money for a small brake kit for 15 or 16's right now.... I want some aggressive cams and the FP red and I'll be happy for a while
I think my car will provide an excellent example of the Green/Red difference and I can provide weights and things like that... it's just a matter of dealing with some downtime to sell the green and coming up with the rest of the $$$.
1/4 mile comes within the next 2 weeks. I'd really like to toss in a set of cams but I can't really afford to do so right now... I really want a 10.99999 but if I can hit 11.0-1 on a 75k mile completely stock motor other than cams and head studs I'd be happy for now.
I think my car will provide an excellent example of the Green/Red difference and I can provide weights and things like that... it's just a matter of dealing with some downtime to sell the green and coming up with the rest of the $$$.1/4 mile comes within the next 2 weeks. I'd really like to toss in a set of cams but I can't really afford to do so right now... I really want a 10.99999 but if I can hit 11.0-1 on a 75k mile completely stock motor other than cams and head studs I'd be happy for now.
