Getting closer 10.882@125 stock IX turbo
Killer passes Lucas, sorry to have missed it!
It was really impressive to watch the car continue to pick up power all the way to 513whp the other day, but you're always so mellow about records
Tom
Tom
Heres another
for you and the guys at English Racing!
Hope you do plan to stick with the stock turbo for a bit longer.
Have you had a chance to weigh that sucker after ditching the 100lbs with the mods or just in general for that matter?
I'm thinking since my car's on the lighter side already that i may join in on the stock turbo fun after we get another crack at a low 10 sec high 9 sec pass w/ the 35r.
I'm not really interested in throwing a full cage in my car at this point
Congrats
Gotta love those big numbers, fast spool and quick et's
So you just flat footing it or using tephra's nlts patch?
I've had the patch forever but never turned it on at the strip
I have the NLTS but setup off the bottom switch which I had to wire in a reverse relay. The NLTS off the top kills the ET and makes the car annoying to rip on if you are not NTLS.
Do you have the new V5 patch? It's setup with load and throttle position permamiters so you will not get those blips when your lift shifting. I use the NLTS patch at the track and so far so good.
