Top 15 Fastest/Quickest Stock Appearing Turbos for 2008...
Old Sep 2, 2008 | 10:31 PM
06MREvo's Avatar
Originally Posted by shunderwunder
Don't forget to add the guys from the stock turbo list. After all they are stock apearing & some of them are in the 10's or low 11's.
By stock appearing i am referring to FP green or FP red equipped cars.
Old Sep 2, 2008 | 10:40 PM
shunderwunder's Avatar
I could see having a green list or a red list but I think a stock appearing list should include stock turbos too. Just my 2 cents. Personally I'd rather see separate green & red lists since they aren't the same thing anyway. I know it's more work, but it gives better refrence to each turbos potential
Old Sep 2, 2008 | 10:43 PM
RACE MAN's Avatar
Anibal BBQ Evo IX from PR did 9.5 @ 142 Allboost RED Turbo , Monroig AEM Tune, 1.42 60ft same car did 9.9 on the green at 137
Old Sep 2, 2008 | 10:49 PM
06MREvo's Avatar
Since there already is a fastest stock turbo list there is no reason to add them to this. I agree with the 2 separate lists for green and red turbos, but at the moment there aren't enough people interested in this list or enough times for me to do 2 lists. I have no problem doing 2 lists but there aren't enough people yet, if i get at least 8 people on here with greens and 8 with reds ill do 2 lists.
Old Sep 2, 2008 | 10:51 PM
06MREvo's Avatar
Yup, i saw both of those videos...badass ...if you don't mind raceman could you put the times in the correct format for me and ill add them to the list...
Old Sep 2, 2008 | 10:59 PM
good luck with the list(s). i know it sucks trying to set something like this up & keep it updated. I think the interest will come. It just takes a while for enough people to run across the thread.
Old Sep 3, 2008 | 05:33 AM
PPI's Avatar
PPI
Screen Name - Date - Main sponsor - Evo Generation – Brief Sum of Setup - ET/MPH
Looks like I can get on the list!
PPI /Wayne - 8/31/008 - PPI - 04Evo8 - 2.0,Green,AEM,E85 - 11.10 @ 124.89
Old Sep 3, 2008 | 07:30 AM
nitz's Avatar
It does seem accurate but because it is only from an ECU log i am not going to list it sorry.
no problem, i understand. however, here is my timeslip and i don't see any reason why you can't list my ET. you can just leave me out of the mph list until i get back there. you don't know the crap we have to put up with down here at the track.
Old Sep 3, 2008 | 08:09 AM
8thWonder's Avatar
Looking forward to your times Lecon ...maybe we can hit up darlington next week...
Sounds good! I've got to get DB to look at my E85 logs before I go though.
Coheterojo, get your times up mang!
Old Sep 3, 2008 | 09:07 AM
06MREvo's Avatar
I posted the times up there to what i thought it would look like in the correct format, obviously some changes need to be made, so when you get a chance, if you could let me know what to change/correct, thanks.
Old Sep 3, 2008 | 09:11 AM
06MREvo's Avatar
lists are updated...thanks for the time slip nitz and nice times PPI!!!
Old Sep 3, 2008 | 09:18 AM
9sec9's Avatar
The numbers should NOT be rounded up, nor the second digit dropped. The list already contains ROUNDED numbers. Use the timeslips. I believe the PR car is a 9.59 (not just 9.5) and the mph I saw was 141.97, not 142. The track doesn't round the numbers, neither should we.
ADDED the timeslip for ease of documentation.
Old Sep 3, 2008 | 09:22 AM
06MREvo's Avatar
I agree, i asked raceman to correct me on the times and format. I just put the PR car up on top of the list so i don't have to do it later. Once i get the the time slip i will change it and put the correct times.
Old Sep 3, 2008 | 09:24 AM
9sec9's Avatar
OKIX(Tony) 8/17/2008 / Forced Performance/ 06EvoIX/ 2.0, FP-Red, AEM, Import/ 10.25 ET
OKIX(Tony) 8/17/2008 / Forced Performance/ 06EvoIX/ 2.0, FP-Red, AEM, Import/ 141.67mph
Old Sep 3, 2008 | 09:46 AM
06MREvo's Avatar
great times...thanks man...
