MT motorcycle slicks
2 of mine beaded up fine and 2 refuse, they have a spot in each that stay bunched under the rim...100psi didn't work and they blew off the rim. Not sure what to do about that.
, I've heard they can be a bish.... maybe I should get 5 like some people have said....
Make sure the inside hump in the rim is lubed as well. If they wont get past that leave them sitting in the sun for a while with pressure in them and they will probably pop up.
-Emery
-Emery
I tried both, even tried straps to get them to buldge out instead of up. A friend of mine saw me at the track last night and asked me to take them to him since he mounts difficult slicks all the time. I'm getting a new set of daily driver wheels/tires soon so that'll free up another set of stock rims to do this and in them mean time I'll keep racing on the BFG DR's
10.4 with a 1.68 can easily be a 10.2 with a 1.58 60ft
.. Mark
I agree, my first two passes I didn't do a burnout...just rolled up and spun my *** down the track... The third I rolled through and out of the water, stopped, tached it to the moon and let a rip, it helped quite a bit. I'll resume experimenting with mounting the slicks soon after I get another set of rims. That ought to help quite a bit vs the BFG
It's not really all that much more for a set-up like mine once you factor in having to have another set of wheels for the MT motorcycle slicks.
Mine was:
Willwoods - 900
Rotas - 400
QTP's - 600
If you can sell the oem Brembo's for say $400 then it's not that much more plus you still have a set of stock wheels/tires for cruising.
Now when will someone try stuffing a 275/40 MT DR on their Evo.......i've seen some on an STI before.
I was going to try out the MT motorcycle slicks before i went w/ the QTP's but wasn't sure about fitment and also about the over rolling dia and my engines rev limit.
What do you guys cross the traps at w/ those on?
Mine was:
Willwoods - 900
Rotas - 400
QTP's - 600
I use them a lot of times and they handle great on high speeds and the grip in the 60ft is crazy.Recently I cut 1.44,1.45 and 1.46 on BVP Evo X 10.7, in PR The Blue Evo X that did 10.9 I cut 1.42 and in Speedclub MR I cut 1.36 , 1.37 and 1.39
This Tires are cheap and the work really great.
Oscar @ CFT
Oscar @ CFT
Oscar @ CFT
Oscar @ CFT
I have seen 225-45-17 but not 245
