MT motorcycle slicks
Old Jul 1, 2009 | 02:38 PM
  #121
evovin's Avatar
Nice!^
I know buddy club/Enkei RPF 1/Kosei TS has 17/7-5-114 but don't know what off set to get without using spacers?
Old Jul 2, 2009 | 12:30 AM
  #122
dambikeracer's Avatar
What width rim are you running for the Motorcycle tire??? 7" as well?
Old Jul 2, 2009 | 10:05 AM
  #123
dsmfan95's Avatar
Yes mine are 7" wide.
Old Jul 2, 2009 | 12:07 PM
  #124
kouzman's Avatar
Is this true that these tires are a bit scarry when braking? What's the pressure that you guys use? Any 3300-3400 lbs cars using them? I am still full interior!
Old Jul 2, 2009 | 03:28 PM
  #125
What 7" rim will clear our front brakes??? Looking for the lightest wheel possible!
Old Jul 2, 2009 | 03:30 PM
  #126
PATRICK B.'s Avatar
The only ones i've seen are the ones that pr evo had and the ones Dave B had on his RS the last time out at the track when he was having tractions problems all they way into 3rd gear.
Old Jul 3, 2009 | 11:53 PM
  #127
What rims are these???
Old Jul 4, 2009 | 12:09 AM
  #128
Sorry found them, Thanks
Originally Posted by EVO8_PR
Indy Performance model 4258 they didn't have the black ones in stock
Old Jul 4, 2009 | 12:41 AM
  #129
evovin's Avatar
So those ^ doesn't need spacers in the front?
Old Jul 4, 2009 | 08:29 PM
  #130
MOREPSiTEHBETT4's Avatar
12 or 15 lbs per wheel?
Old Dec 27, 2009 | 10:08 AM
  #131
TALONGT's Avatar
Has anyone on here ran the 3158M 27.0/10.0-16M ? I don't want to get rid of my willwoods and buy new 15" rims?
Old Dec 27, 2009 | 10:16 AM
  #132
TALONGT's Avatar
Originally Posted by Martin@AMS
Guys just because quite a few cars running them haven't blow a tire and careened into a wall at a 140mph doesn't mean it's safe. First look how much these tires weigh compared to a similar car sized tire, they are not meant for these type of loads. I know there is a safety factor but do you know the factor is, you're just guessing.
I truly hope this doesn't start a trend of everyone running them because when someone's car gets totaled or worse, someone get's hurt, it won't be a good day.
So if they are rated at 500lbs each and during a hard launch you can have roughly 75% weight transfer or more. A full weight street evo at 3400lbs with driver will already have about 1500lbs on the rear tires, so that's 750lbs per tire roughly. On a launch that will probably go up to 1200-1300lbs per tire, that's almost 3 times the rated load!
I've talked to MT about this already. It's really not safe to run these on cars. I know this sport is inherently dangerous but why blatantly put yourself at risk like this?
What tire do yo suggest then Martin?
Old Dec 27, 2009 | 01:06 PM
  #133
CMB's Avatar
CMB
Do you need to run tubes with these?
Old Dec 28, 2009 | 09:43 PM
  #134
R/TErnie's Avatar
Bring tubes and nails.... for your coffin.
Old Dec 28, 2009 | 09:50 PM
  #135
TTP Engineering's Avatar
We have run these tires to 1.57 so far.
