Wider Tires Affect MPH
Old Dec 3, 2008 | 04:33 PM
blackdemon's Avatar
Im unsure on how does running wider tires affect the MPH at the drag strip. Give me some input guys. Im running 255/40/17 size tires.
Old Dec 3, 2008 | 04:38 PM
TTP Engineering's Avatar
No. Your tires are now smaller than stock which is a circumference problem, not a width problem.
Old Dec 3, 2008 | 04:42 PM
jxs1984's Avatar
smaller means slower?
Old Dec 3, 2008 | 04:44 PM
blackdemon's Avatar
So a smaller tire would show lower traps?
Old Dec 3, 2008 | 04:45 PM
m4tt VIII's Avatar
Wider tires will not affect your MPH in the way that the circumference of the tire will. Depending on what brand/type of tire you may get better/worse traction I guess... but width shouldn't affect MPH other than maybe getting a better launch, etc...
Old Dec 3, 2008 | 04:50 PM
sikrsix's Avatar
Smaller circumference will make acceleration faster... but may have you running out of gear and needing to add another shift.
Old Dec 3, 2008 | 04:52 PM
TwistedEvo8's Avatar
Like he said Width will not effect your trap speed other then more rubber on the road for traction. Its the size of the wheel wall you need to worry about and rim size. The Smaller the wall size or rim the more rotations you need to go so far, so more Tq and the bigger the tire the higher the trap speed.
Old Dec 3, 2008 | 04:53 PM
blackdemon's Avatar
so is my trap about right for my power output? Trap of 113
Old Dec 3, 2008 | 04:55 PM
I would say its about right. All depends
Old Dec 3, 2008 | 05:10 PM
blackdemon's Avatar
What im getting at is. I ran a 12.1 @ 113mph with a 1.81 60ft shifting at 7500rpm. Car weighed 3360lb that day. Say if i would have shifted higher and got the 60ft down to say 1.6 how much faster would my time be. I know theres alot of variables.
Old Dec 4, 2008 | 03:18 AM
blackdemon's Avatar
bump
Old Dec 4, 2008 | 06:31 AM
CBRD's Avatar
wider tires have more aerodynamic drag... more frontal area...
cb
Old Dec 4, 2008 | 08:29 AM
Audi2ptzero's Avatar
Wider tires will effect trap speed since there is more rolling resistance. This is exactly why the FWD cars run skinnies in the rear and RWD cars run skinnies up front.
Even running less tire pressure effects trap speeds since it too increases rolling resistance.
Old Dec 4, 2008 | 08:39 AM
blackdemon's Avatar
so how much mph would it take off the trap speed? estimate?
Old Dec 4, 2008 | 08:54 AM
Wider tires will affect performance less than the tire pressure being used.
