Sooo close need help
Old Jan 31, 2009 | 07:58 PM
jdmtim's Avatar
Ok my goal is hit 11's im so close i dont know wat else to do
my setup
kelford 272
xtreme boost custom intercooler/intake
megan dp/tp
Hks Highflow cat
walbro 255
Hdss clutch
stock flywheel
stock turbo of course
Jestr pump gas tune
i dont know if my shi**y tires are the problem i have Ziex ZE-912 255/40
this was my best time at the track after that it just got worse..
number 42 me course
im launching from 6200
any other tips
Old Jan 31, 2009 | 11:54 PM
RyuEvoIX's Avatar
tire pressure?
Old Feb 1, 2009 | 10:35 AM
Turbojunkie's Avatar
my setup
kelford 272
megan dp/tp
Hks Highflow cat
walbro 255
Hdss clutch
stock flywheel
Jestr pump gas tune
number 42 me course
any other tips
i would lower your two step. Each person has his own technique, but i find that 5200 2step and 22 psi in the front and 20 in rear net me 1.6x on 245 fedrals. Id definalty put some race gas in and get some more mph out if and a hit an 11 for sure. good luck
Old Feb 1, 2009 | 03:46 PM
jdmtim's Avatar
Originally Posted by RyuEvoIX
tire pressure?
my tire pressure was like 35 all around
Old Feb 1, 2009 | 06:10 PM
RyuEvoIX's Avatar
Try 22psi in the front and 23psi in the rear as a baseline with a 5800rpm 2step. Then adjust accordingly based on results IE: bogging or spinning. Good luck.
Old Feb 1, 2009 | 06:16 PM
Cyloc's Avatar
35 psi....what are you running truck tires.....They should be no higher than 32 if the are stock 17's
Other than that I would use the pressure ryu said. If you get you 60' to a 1.6 then you are in the 11's.
Old Feb 1, 2009 | 11:28 PM
SHhhhh's Avatar
Are you shifting to 5th?
Old Feb 2, 2009 | 07:09 AM
jdmtim's Avatar
im spinning a little but could it because they guys at the track wet up everything when they water the water pits
Old Feb 2, 2009 | 07:13 AM
jdmtim's Avatar
not stock tires azenis ze912
but ill try the tire pressure thing
no. im hitting redline in 4th
Old Feb 14, 2009 | 10:54 AM
Carloverx's Avatar
I'll have different cams (gsc s1), upper and lower icp, ported exhaust manifold, 02 houing.
Otherwise, same mods. I'm shooting for an 11.9 also. keep us up to date if u hit the 11.9.
Also, is this a 6 speed? (if not, and ur hitting an redline in 4th, i guess i'll need to go to 5th )
Old Feb 14, 2009 | 11:20 AM
jdmtim's Avatar
im 5 speed!! i havent been to the track since.. idk if should take more weight out of the car??
Old Feb 14, 2009 | 11:57 AM
Carloverx's Avatar
take "more" weight out? what did you take out so far.
Hearing that you're on a five speed really discourages me.
Old Feb 14, 2009 | 12:13 PM
marrrk's Avatar
ryuevoIX pretty much covered everything, i mean just look at his times!! 60ft is a huge diff in et also that hks cat imho should deffinitly go away or gut it. like i said listen to ryuevoIX and your there! good luck
Old Feb 14, 2009 | 12:18 PM
2003lancerevo8's Avatar
Some Weight Reduction
lower the heck out of the tire pressure
Ditch the Hi Flow Cat and run a test pipe
11's are there....
Old Feb 14, 2009 | 02:24 PM
jdmtim's Avatar
nooo i have a megan racing test pipe.. when i go to the track i keep everything in the car.. i see some cars wit out the back seats and passenger seat and spare tire....
