atcooo
Old Apr 1, 2009 | 06:02 PM
kmartizdatruth's Avatar
atcooo
finally ran the car last night with a good clutch and tranny. and i pulled a 12.4 several times last night with two trap speeds of 109 and the last with 112 "didnt shift to 5th" tires kept spinning of the line no matter how much i tried to slip the clutch "bf goodrich kdw2 245/40/17" with a 60ft of 1.8 any suggestions for improving my time at the track.
dyno-347.99hp 346torque
Old Apr 1, 2009 | 06:34 PM
alianum777's Avatar
just curious as to what your mods are? if you dont mind
Old Apr 1, 2009 | 06:38 PM
invidia o2 housing
megan turboback
hallman mbc
megan exhaust manifold
brian crower 272 cams
walboro 255lph fuel pump
injen intake and intercooler pipes
agp fmic
excedy twin disk hd clutch and flywheel
and a tune
Old Apr 3, 2009 | 05:13 AM
evojoe90's Avatar
i hate atco because there is no way to avoid it.
Old Apr 3, 2009 | 05:30 AM
mike1023's Avatar
what rpm are you launching at?
i think i can help you get your 60ft down
Old Apr 3, 2009 | 03:20 PM
6200rpm..........please i will take any advice to run faster times
Old Apr 3, 2009 | 03:24 PM
mike1023's Avatar
lower it to 5100 try that if bog try again if still bog go up another 100rpm keep going in till you get best 60ft.
and with small turbo a little bog may just help you big time.
Old Apr 3, 2009 | 03:25 PM
mike1023's Avatar
what tire psi were you running? and did you check all them before going down the track?
here is a vid of me at the track running the 12.4 with the 1.860ft you can here my tires going
http://www.youtube.com/watch?v=PVUMuUf1xUo
Old Apr 3, 2009 | 03:26 PM
yea i had them at 35psi my first run and had a crappy 60ft and lowered them to 30psi and it improved to the 1.8
Old Apr 3, 2009 | 04:35 PM
mpevo8's Avatar
who tuned it ?
Old Apr 3, 2009 | 05:07 PM
mike1023's Avatar
ya i would try and turn them down to around 24psi cold and 26psi hot
sound be good there.
Old Apr 3, 2009 | 06:00 PM
thanks man i will def try that next time
Old Apr 3, 2009 | 06:02 PM
mike1023's Avatar
np if need any more help aim me or call
Old Apr 3, 2009 | 10:09 PM
PeteyTurbo's Avatar
Atco sucks for getting traction on an awd car period, but I still go there for ****s and giggles
The only way to cut a decent time there is to "clean" the tires off before you run..I got a 1.7 on this run, not great, but good for my car at Atco nonetheless
http://www.vimeo.com/1577587
