Ran a 10.59 @133
Old Jun 14, 2009 | 08:58 PM
redevo58's Avatar
Ran a 10.59 @133
I ended up going to the track yesterday and ran on drag radials. I took indys advice and stuck to an 8 inch rim and i couldnt be happier. I did not heat up the tires at all and ran them at 29 psi each run
28psi of boost = 560whp weekend warrior
1st run first time at the track with the drag radials on 17's( ran on 18's n street tires for 4 years) i rode the clutch to long and i ended up bogging( 2.0 60 ft) then missing second. Ended up running a 12.4 @122.
2nd run got a great launch but i babied all my shifts a bit due to missing second the first run
60ft....... 1.619
330....... 4.478
1/8........ 6.859 @ 102.31
1000 .... 8.900
1/4....... 10.594 @ 133.66
c-16 @ 33psi(only saw 29psi) whp=???
The track was going to close in a bit and i switched to my c-16 map. Originally tuned for 38 psi but i lowered down to 33psi due to the c-16 being old and i wanted to make sure to would run safely. Something was off since i was only seeing about 29 psi and jiggling on my boost gauge this run. I ended up preloading the drive train too much and started to creep forward and i guess i tripped the sensor. it was great launch as well and i felt i shifted more aggressively but i ended up with a lower trap speed? I guess i developed a boost leak or something, the car did not feel like it was cutting out.
60ft...... 1.924( I stared to creep forward n tripped the sensor)
330...... 4.856
1/8....... 7.237 @ 102.22
1000.... 9.288
1/4....... 10.988 @ 133.12
Old Jun 14, 2009 | 09:01 PM
Brian's Avatar
Nice man, wish I could have been there to see you run it. I foolishly booked an event over the shootout that took priority.
Old Jun 14, 2009 | 09:19 PM
redevo58's Avatar
Thanks Brian. I had a blast, and im sure i ended up being the quickest import there. Those pics are of my first run. I posted on nasioc if any one had any pics/vids of my runs. One guy said his buddy did and i'm hoping that it was the 10.59 run.
Old Jun 14, 2009 | 09:22 PM
kouzman's Avatar
congrats man!
which DRs are you using?
Old Jun 14, 2009 | 09:25 PM
redevo58's Avatar
Originally Posted by kouzman
congrats man!
bfg 225/45 17. I love them so far at 29psi with no burn out i still hit a 1.619 60 ft. Hopefully i can lower the time by heating them up and playing with the tire pressure.
midwestmonster's Avatar
Awesome times man! Great job.
Old Jun 14, 2009 | 09:32 PM
fugiwara's Avatar
what size snail?
Old Jun 14, 2009 | 09:35 PM
redevo58's Avatar
Thanks guys and its a ams 37r turbo kit.
Old Jun 15, 2009 | 07:52 AM
PATRICK B.'s Avatar
Is there a trhead where i can learn more about your car? mods?
Great #'s for how little prep you had w/ the car
Old Jun 15, 2009 | 08:04 AM
redevo58's Avatar
actually i do have alot done here is the link to my set up. I just never posted about my car. In the pics i have 18 inch te-37's I now have a cf hood and 17inch rpf1's with drag radials . I also have bc racing coilovers for suspension mods and trailing arm bushings.
link
http://www.amsperformance.com/d_ponce.php
Old Jun 15, 2009 | 08:15 AM
PATRICK B.'s Avatar
link
Thanks for the link!
Nice lookin evo and great build parts!
That thing should def get ya in the 9's soon once you get that thing in boost on C16.
Best of luck
Old Jun 19, 2009 | 11:33 AM
redevo58's Avatar
Best of luck
Thanks. That is the goal.
Old Jun 19, 2009 | 11:55 AM
PATRICK B.'s Avatar
For you and me both
