Project White, stock ECU record(?), low 10's
I think if you were able to log you might of been able to tweak it to boost the 1/8 MPH...the back end is tremendous. Now that you have ventured into the stock ECU im sure the record wont last too long
I got one or two logs from the car, then it went into some crazy crap when I stopped the logger it gave me an error that took up most of the page, the datalog was a HUGE red X across where the graph would be and the computer would completely lock up. I had to go into the task manager to shut it down. On the 2 logs I did get, there was a knock count of 1 in 3rd gear for one short instance. I am still not logging AFR's so I had Trent glance over at the wideband and said it was pegged reading just ---- meaning it was fatter than 11.0:1.
It's all good. I am happy right now. I think I will try the speed density mod on the car next just to do it. I think it will pick up another 20 whp from it and then maybe run the car at the shootout in August.
Yes there is going to be a video. Give me a bit of time and you should be able to see it tomorrow afternoon.
Going through music at my house right now to try and find what I want to use.
Now THAT's a wicked street car!!
2.3 + slicks + 4.11 final drive = 1.4's and 138mph traps....... Evo's have come a long way, thanks to guys like you.
"Average Joe" has a new formula to follow!
david,
any comments on changing from the aem back to the stock ecu on speed density?
