queston need help - ran slower.
Old Jul 25, 2009 | 11:21 AM
evil6819's Avatar
i have a evo 9 i just put the fp4 cams and reflashed it again i went to the track and ran a slower time than before i ran a 12.9 i ran a 12.5 before i had cams, i also noticed that i bogg all the time now at take off why is that
Old Jul 25, 2009 | 11:52 AM
chaotichoax's Avatar
is your stationary rev limit set the same?
same track prep?
tire psi?
more info about the reflash?
boost leak test?
you are asking a very broad question
Old Jul 25, 2009 | 05:33 PM
evil6819's Avatar
queston
on my flash i have intake full exhaust with ic piping fp4 cams and my rev set to 6, and the track is the same place also what tire psi is the best for drag racing
Old Jul 29, 2009 | 05:03 PM
generalu's Avatar
You should log your hp instead of 1/4 mile times. Maybe you just had a great launch the first time, no so great this time around.
Old Jul 29, 2009 | 06:03 PM
DIDYSIS's Avatar
Well some times its a fluke, try raising the 2 step, practice, you will get better times.
Old Jul 29, 2009 | 06:13 PM
Mellon Racing's Avatar
post the before and after hp/tq and timeslips...impossible to help without any data.
Old Jul 30, 2009 | 10:39 AM
wtmodnar's Avatar
if you're bogging off the line all the time now, I can see why you run slower. If you get that bogging fixed I'm sure you'll do about the same if not better time. gl
Old Jul 30, 2009 | 11:15 AM
kouzman's Avatar
But even if you are bogging off the line, what was your trap at the 12.5 and the 12.9? Did it go up, down, the same?
Old Jul 30, 2009 | 11:51 AM
project_skyline's Avatar
No body can help you without some dam info. Track slips, logs, something!
Did you retune after installing the cams?
Old Jul 30, 2009 | 09:04 PM
TTP Engineering's Avatar
Your mivec tables are not correct for the cams.
Old Jul 30, 2009 | 10:14 PM
Most-Wanted's Avatar
what were the mph numbers before and after?
