the best 2-step rmp range for evo x
i was wondering what is the best rpm for 2-step on a evo x and what kind of boost do u want to be at to get the best 60' times. this is for evo x only
Eric, there is no answer for that question you should know that!!
It's all about the track prep, tire combo/pressure. You will only know what works for a given setup when you give it a shot.
I start all of my tunes at a defaulted 6,000rpm..Work up from there. Also how much boost off the line etc will greatly play a role in what needs to be adjusted. For a stock turbo, 6-6500 rpm will be a good start on a radial tire on a decently prepped track.
