Suspension setup
Old Aug 12, 2009 | 01:50 PM
juanmedina's Avatar
Suspension setup
I am trying to lower my 60' and I wonder if my suspension is killing my launches.
I have a set of Megan street coilovers, they have 32 adjustable settings and they are set at 9 very stiff. How do you guys set your coilovers for drag racing? I am pretty sure that I need to encourage weight transfer.
Features:
- Spring Rates: 8kg Front and 6kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
TY
Old Aug 13, 2009 | 07:59 AM
juanmedina's Avatar
bump....
Old Aug 13, 2009 | 05:54 PM
inco9nito99's Avatar
Here is what I'd do.
1.) Set ride height via corner balance, if it's setup for drag, leave ATLEAST 1.5-2" gap (especially in the rear), do go gangster-squat :P.
2.) Set the alignment for -1.0 front camber, 0 or +1 rear camber, (so that when the car squats on a launch the tyres instead of going massive negative camber and losing contact patch, still has a good sum of contact). Zero toe all around.
3.) Set the tyre pressure to a reasonable amount where you don't spin and you don't bog, (coupled with a proper 2-step RPM for the clutch you're running).
4.) Once you have the corner balance/alignment/tyre pressures taken care of, go ahead and set the dampening at halfway tight all around. Work with what works best for you, ideally you want the rear to squat so leave the rear SLIGHTLY softer than the front. Play with it though to see what works best for YOU.
5.) Once again, play with tyre pressure to optimize '60.
6.) Practice, practice, practice .
HTH .
Old Sep 15, 2009 | 11:18 AM
juanmedina's Avatar
HTH .
Thanks, anyone else
I will back to the track by the end of the month looking to get into the 11s with my full interior 330whp 2800lbs subaru WRX
Old Sep 16, 2009 | 10:16 AM
HyboostN's Avatar
Set it up as soft as possible to allow better weight transfer.
I've seen some guys cut 1.6-1.5's on stock suspension.
A stiff coilover does you no good .
LSD Motorsports
Vendor Classifieds
10
May 18, 2017 03:19 PM
Hoojan
Jul 14, 2016 02:36 PM
ARC_EVO
19
Jul 23, 2008 06:48 AM
ROCK
Lancer Ralliart Vendor Classifieds
Aug 30, 2007 10:18 AM
ROCK
Lancer Vendor Classifieds
Aug 23, 2007 09:50 AM
